Results 1 to 15 of 18
Thread: threading inserts. 16EL etc
12th Sep 2019, 03:52 PM #1Most Valued Member
- 4,255
anyone have a source for 11EL and 16EL threading inserts.
Ordered some LH threading tool holders form CTC so I can cut cut a thread (travelling away from chuck cos i am chicken and will probably crash the tip into the shoulder) but he doesnt have the inserts????.
One can get them from Travers but was hoping for a local if price is right.
12th Sep 2019, 05:24 PM #2Most Valued Member
- 4,887
Do you understand that using a left hand threading tool will add about 10 to 15 mm's to how close you can get to a shoulder.
12th Sep 2019, 06:08 PM #3
Hi Eskimo,
This is a picture of one of my insert threading tools. That gap between the work face and insert tip is just about 1.5 mm. I haven't got a picture of my other one but its identical, but faces the other way. You need both left hand and right hand inserts. Mine came from either Aliexpress or Banggood and both came with a box of ten tips plus the one in the box with the tool. I paid less than ten UK pounds each for mine.
I only have carbide insert threading tools because at the moment I find it very difficult to grind HSS tool bits the right shape and angles. By the way you will find that 55 degree carbide tool inserts very expensive ! 60 degree ones are as common as muck. (Dirt) Yorkshire slangBest Regards:
12th Sep 2019, 07:07 PM #4Most Valued Member
- 4,887
No relivence to threading but is dirt a slang term over their.
12th Sep 2019, 07:34 PM #5Philomath in training
- 6,542
Tagutech make them, and General tools stock that brand, so may have them or be able to get them for you.
12th Sep 2019, 09:38 PM #6Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
Does this eBay link help ? https://www.ebay.com.au/itm/Clevelan...frcectupt=true
All The Best steran50 Stewart
12th Sep 2019, 09:51 PM #7
12th Sep 2019, 11:10 PM #8
12th Sep 2019, 11:48 PM #9Most Valued Member
- Healesville
- 2,129
Eskimo when i had a look for your insert numbers i found circlip groove inserts? https://www.aliexpress.com/wholesale...itch_new_app=y
Are these the inserts you are after? https://www.aliexpress.com/item/3298...chweb201603_53
If not then a photo of the tool holder and a couple of measurements of the insert needed might help.
cheers, shed
some more here https://www.aliexpress.com/item/3287...chweb201603_53
13th Sep 2019, 07:03 AM #10Most Valued Member
- 4,887
How many of the inserts are you after in size 16 EL and are you also looking for IL as well in 16.
13th Sep 2019, 09:49 AM #11Most Valued Member
- 4,255
13th Sep 2019, 09:56 AM #12Most Valued Member
- 4,255
13th Sep 2019, 10:06 AM #13Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
13th Sep 2019, 10:07 AM #14Most Valued Member
- 4,255
13th Sep 2019, 10:33 AM #15Most Valued Member
- Healesville
- 2,129
Eskimo this how i cut R/H threads away from the chuck, there is no turning cutters upside down.
I am pretty sure the inserts that you need would be available on aliexpress but without the tool holder number or a pic or insert measurements .......
Threading close pipe nipples with a hand threader and block type threading dies.
By aametalmaster in forum METALWORK GENERALReplies: 5Last Post: 11th Sep 2015, 07:22 AM -
Ext threading inserts - I DONT GET IT!!!
By eskimo in forum METALWORK GENERALReplies: 18Last Post: 12th Apr 2015, 10:15 AM -
Where to buy inserts?
By Bidgee in forum METALWORK GENERALReplies: 6Last Post: 29th Nov 2010, 11:28 AM -
APMT103504PDER inserts
By eskimo in forum METALWORK GENERALReplies: 17Last Post: 9th Sep 2010, 05:59 PM -
Threading Inserts
By 19brendan81 in forum METALWORK GENERALReplies: 4Last Post: 28th Oct 2009, 04:24 PM
