Page 1 of 2 12 LastLast
Results 1 to 15 of 22
    Aug 2009
    Sydney, NSW, Australia
    1,841
    Default Bearing Journals, Tig, Spray Welding? Q
    Hey guys a really cool video just popped up on my youtube feed of a guy repairing a electric motor shaft the bearing journals were over worn now he spray welded the journals how come u cannot just tig weld something like this to build up the material? something i have wondered for a while since spray welding and machining one journal i have been quoted $440
    so interested to hear why tig welding journals is not a common practice
    Jun 2007
    sydney ( st marys )
    64
    4,890
    To much heat, to slow.
    Aug 2009
    1,841
    Thanks Pipe, does the excess heat warp the sgaft or change the structure of the steel or something?
    6,473
    From a hobbyist point of view, yes you can tig the shaft and build it up, then set it up in a lathe to turn it back to size ! Though to get a good bearing surface after turning you would grind it to finished size.
    As Pipeclay says too slow to be done that way commercially.
    Aug 2009
    1,841
    Thanks Baron
    Nov 2009
    australia
    57
    It can be done quite successfully with the old welding rod as well as metal spraying, both need to be turned to size after being done.
    Some jobs you needed to use the big lathe ( 5 mt bed ) to do them.
    Tig welding is far to slow compared to a big rod turned up high.
    Done heaps of them both ways over the years.
    Metal spraying has now got a few restrictions on who and where it can be done to, something about the over-spray dust having to be removed so it doesn't harm the operators lungs.
    Not a nice sort of job to be doing all day either, noise and the dust are real bad.
    Aug 2009
    1,841
    I inquired about a outboard crank journal and was quoted $440 and said its not worth doing i think the machinist didnt know the value of the engine
    How come the cost is very high to have a crank journal repaied by welding?
    6,473
    Hi Gazza,
    Probably because they didn't want the job !
    Oct 2010
    melbourne, laverton
    1,910
    Default maybe
    I think there is less skill involved metal spaying than tig welding. plus less heat ect.
    i worked in work shop once where there was a lathe away from the other that was used
    for rough jobs like metal spaying.
    Oct 2010
    melbourne, laverton
    1,910
    Default ask
    how did you fix it?
    Aug 2009
    1,841
    I didnt fix it i just sold parts to recoup my money i paid out on buying it, the engine i have now threw a conrod and absolutely demolished the crankcase so i bought another powerhead from ebay and had it crated down from darwin to sydney this was back at the start of the year and i only just a week ago done a compression test on the used supposedly good running new to me powerhead and it was down on compression on one cylinder so it may need that one journal repaired
    May 2011
    Murray Bridge S Aust.
    5,959
    How come the cost is very high to have a crank journal repaired by welding?
    When you look at being charged $110 per hour or part thereof, it's not hard to see the cost.
    Welding time possibly 1hr+ as you have to watch the distortion, setting up the crank in the lathe to machine the journal, an other hour as it's not the sort of thing that can be shoved in and she'll be right Jack type of thing.
    Another hour and a half, it's hard work machining weld metal, hang on "SMOKO" break by the time he gets back to work, there's 20 minutes gone, the BOSS wants his profit out of it, call it 1/2hr, so there's your $440.00
    That is a reasonable hourly rate for work like that, some can be upto $200 for real specialised work.
    HTH
    Aug 2009
    1,841
    Kryn when u stretch it all out it seems like a lot of work i know lathe work takes time and being prescise too eats up time and the bloke i seen is by far the cheapest machinist around
    Wish it was a job easily done at home but its far out of my capabilities and the tooling is next level industrial equipment
    Dec 2005
    South Australia
    1,657
    I saw that video, I was not impressed at the final finish maybe I'm just too fussy
  15. #15
    Sep 2006
    Mallacoota,VIC,Australia
    53
    1,010
    My old Boss use to use Paul England to do the outboard crankshafts. He had used some other repairers before Paul, but there work was crap. I remember Paul stopped doing outboard crankshaft repairs, but that was a long time ago. Paul England does have Marine Engines listed on his website, but he may be referring to bigger engines. I seem to remember that it was about $200 to $250 to do a crank journal, but we are talking around 1996 to 2005 when we were doing a lot of rebuilds so wages were a lot less then (the $440 sounds reasonable at current labours rates). I know you sold the motor off and not knowing what motor you had, but did you think to look for a secondhand crankshaft ?.
    All The Best steran50 Stewart
  1. Dry Moly Spray
    By triden in forum GENERAL DISCUSSION / OFF TOPIC
    Last Post: 7th Jun 2018, 09:46 PM
  2. Spray gun - where to start?
    By ventureoverland in forum METALWORK GENERAL
    Last Post: 9th Feb 2016, 01:08 PM
  3. Spray Guns
    By Keith_W in forum METALWORK GENERAL
    Last Post: 14th Jan 2013, 09:31 PM
  4. Anti-spatter spray
    By Gavin Newman in forum WELDING
    Last Post: 29th Apr 2012, 10:27 PM
  5. Spray Transfer??
    By hux in forum METALWORK GENERAL
    Last Post: 23rd Feb 2007, 08:34 AM
