Results 46 to 60 of 76
14th Sep 2019, 09:13 PM #46Senior Member
- Perth, Western Australia
- 67
- 362
14th Sep 2019, 09:28 PM #47Most Valued Member
- 2,651
16hp, ST2 engine manufactured in 1979 from what I can work out.
Not sure what the KG ratings on the chassis plate mean.
14th Sep 2019, 10:57 PM #48Senior Member
- 67
- 362
I cannot really say I`d assume one is machine weight, the other maybe load. Load use to be on its own plate.
Is it rear wheel steer or articulated ?
Tony
14th Sep 2019, 11:33 PM #49Most Valued Member
- 2,651
Just rear steer.
Articulated would have been nice - a backyard mini-Franna!
15th Sep 2019, 12:01 AM #50Senior Member
- 67
- 362
Mini Franna would be nice.
It might be earlier than 79. Rear wheel steer was pretty much old hat by that stage.
Still an interesting piece of equipment.
Tony
15th Sep 2019, 12:15 AM #51Most Valued Member
- 5,942
15th Sep 2019, 02:06 AM #52Senior Member
- 67
- 362
Throw in the right valves and you could have 4 wheel steer and a 4 wheel crawl option.
Tony
15th Sep 2019, 01:44 PM #53Most Valued Member
- 5,942
Set the Lister up with hydraulics, a couple of hydraulic motors on the inputs of the diffs and you'd have 4WD and steer. Hook a ram onto the jib and you have the ULTIMATE piece of moving stuff around the yard machine.
Sneek a few hydraulic rams in and build yourself a dozer, while your at it, fit a mower deck to it, and she will be happy as only one machine is needed for everything in the back yard
If she's into planting stuff, mount a post hole borer to save her digging!!!
15th Sep 2019, 02:58 PM #54Philomath in training
- 6,540
Not so fast there...
That thing was originally designed for carting concrete in a tub sitting between the wheels. As soon as you start putting on dozer blades, hydraulic jibs and the like, you need to be careful that the extra weight won't tip it over, especially on a slope.
It is a cool little vehicle though.
15th Sep 2019, 03:20 PM #55Most Valued Member
- 2,651
Our place is flat, so side slopes definitely aren't an issue.
Already has hydraulics Kryn, tested this morning and good for at least 750kg, likely close to 1000kg (but not sure I'd want to remove my 100kg counterweight from the drivers seat at that load though!!)
15th Sep 2019, 05:20 PM #56Most Valued Member
- 5,942
COOL Didn't see the ram on previous pics.
15th Sep 2019, 06:23 PM #57
It don't have to look pretty to do the job.
You will find uses for it you haven't even dreamt up yet.
Best thing about the old stuff, no damn computers in it!!Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
16th Sep 2019, 08:16 PM #58Banned
- Aug 2015
- QLD
- 735
17th Sep 2019, 12:09 PM #59Most Valued Member
- Sep 2010
- Lebrina
- 1,910
Following on from that, the old rule still applies - carry your load as low to the ground as possible at all times and travel slow and steady when loaded. Ideally all moves with the load raised should be straight fore and aft and at a crawl. Make sure that you are on good solid ground too. It gets real hairy really quickly when a wheel sinks with an elevated load.
Brilliant little tool though. A valuable upgrade may be the addition of a load check valve to protect against a hose bursting and dropping the load and also hydraulic creep.
17th Sep 2019, 01:13 PM #60Most Valued Member
- 2,651
Thanks Karl. I was already thinking about the age/condition of the hoses, particularly the one on the raising side of the ram as the previous owner has already had to replace the pressure hose between pump to control valve. All the other hoses look like they could be original in which case they may be close to 40 years old!!
I don't want to fork out the dollars to replace all hoses but think its prudent I do that main lifting pressure one. It reminded me of my father having a hose burst on the ancient International tractor he had.
He was lifting a pallet of brand new faux stone cladding off the delivery truck when they built their current house. Thankfully the only things damaged apart from the stone were his pride and wallet.
I hadn't heard of load check valves, but just did a quick search to find out about them. If I've got it right the valve goes in the pressure line for the load lift, but needs pressure input from the lowering side of the ram to allow it to open?
Scrap yard goodies !
By BaronJ in forum METALWORK GENERALReplies: 7Last Post: 6th Jul 2019, 09:36 PM -
Scrap yard Mill
By Metalman in forum METALWORK GENERALReplies: 0Last Post: 12th Dec 2016, 06:56 PM -
If you go to the junk yard..
By sossity in forum GENERAL DISCUSSION / OFF TOPICReplies: 4Last Post: 24th Nov 2016, 09:09 AM -
lifting and moving heavy things
By morrisman in forum METALWORK GENERALReplies: 5Last Post: 29th Mar 2013, 06:40 PM -
Interstate couriers for small items too heavy for AU post
By .RC. in forum METALWORK GENERALReplies: 24Last Post: 14th Dec 2010, 07:37 PM
