Results 16 to 30 of 76
4th Sep 2019, 09:47 PM #16Most Valued Member
- Charlestown NSW
- 1,673
That was me. I think it was about $150 or $200 to hire for the day. Buying one wouldn't be cheap though. eg https://cranedepot.com/products/1-to...m-gantry-crane
I tonne capacity $3200 approx
Wanting to use something on soft ground (grass) adds a whole new level of excitement though.
peter
4th Sep 2019, 10:11 PM #17Most Valued Member
4th Sep 2019, 10:41 PM #18I used to be an engineer, I'm not an engineer any more, but on the really good days I can remember when I was.
5th Sep 2019, 09:28 AM #19
I have been trying for two days to think of the device the yanks use. Typically for me I am a day late and a dollar short.
Jin poles was the term that I was trying to think of. .Basically the same as you blokes are using based on a triangle either ground mounted or on a trailer or truck. There are lots of images in GOOGLE.
From my mate whose has a Land Rover,"what do you do when you buy a new Land Rover and it doesn't leak?
"Send it back cos its not a genuine Land Rover."
5th Sep 2019, 10:40 AM #20Most Valued Member
- 2,671
Suggestions for lifting heavy items in the yard
Thanks Grahame - hadn't heard of the term Jin Poles.
I've actually used a similar arrangement a couple of years back while helping erect the portal frames for a mate's shed. Frames were assembled on the ground and pinned by a single bolt in their stirrups, then winched up to vertical using a strut somewhat like a single Jin pole. Hard to describe - I'll try to find a photo.
More Landrovers in that piccy too
5th Sep 2019, 01:35 PM #21
Hi Steve, I went down and took a couple of photos of the crane at the local museum this morning. This is a bout a generation older than the one in the nearest town when I was a kid, it had a hand winch on it and from memory a timber pole boom. The whole upright and boom rotates 270 deg in the ground between the stays so it provides a lot of swing and height range. May not suit your requirements as it is fixed in place, and a gin pole type setup with a permanent base might serve better in terms of not taking up as much space, but something like this could be built relatively easily if having a permanent fixture was not an issue.
Edit, sorry about 2 pics on their side, had corrected that prior to posting, but they come out rotated anyway.I used to be an engineer, I'm not an engineer any more, but on the really good days I can remember when I was.
5th Sep 2019, 08:48 PM #22Most Valued Member
6th Sep 2019, 09:45 PM #23Most Valued Member
- Healesville
- 2,129
I had a little Cranville Wombat backhoe that I used as a yard crane, I have seen them for sale recently but the prices they want for them seem to be over the top now.
I paid 1500 bucks for mine with an old tandem pipe trailer.
shed
7th Sep 2019, 03:18 PM #24Senior Member
- Perth, Western Australia
- 67
- 362
I built a similar unit to this one. I used a diff from an old truck and an old 2t workshop crane. Could hitch it up to the front or back of the 4x4. Worked well.
I reconfigured the crane section after I had finished and mounted it on the back of the 4x4.
I have also used the 2 pole setup shown in the tray top pic. I had the poles turned the other way so they were up near the cab end.
Used 2 hand winches to lift the object on to the back of the 4x4. Very shaky but it was only needed for the one lift.
Tony
7th Sep 2019, 03:56 PM #25
Other than saying it came from Google images, I don't know.
I chose it because it was similar to what could be used for the OP purposes- being mounted on a flatbed and the OP had a flatbed.
from reading and seeing pics I know that the basic idea was used a lot in the yank oil fields.
Some of those examples looked flimsy to say the least., but a lot of them were made from drill tube which is pretty tough tube.
7th Sep 2019, 06:17 PM #26Most Valued Member
You just remended me that years ago I used to know a bloke that had something similar mounted on the back of his Suzuki LJ81 ute, he used it for erecting sheds, on the front he had a hydraulically operated bulldozer blade, for getting rough levels. This particular vehicle also had 4 wheel steering.
Back in the 80's you could get away with something like that.
7th Sep 2019, 07:50 PM #27Senior Member
- 67
- 362
You could always swing off the front.
Gin pole setups used a lot in the 50`s and 60`s in the USA for oil field work and telephone companies.
I have seen an old Blitz truck setup the same way at an old gold mine in northern WA.
7th Sep 2019, 08:24 PM #28
Love the power wagons.
7th Sep 2019, 11:01 PM #29Most Valued Member
- 2,671
Yeah - they look like a tough old beast.
Don't think the Landrover is up to this:
https://www.youtube.com/watch?v=XhWu6XBKtqA
7th Sep 2019, 11:24 PM #30
I've had mine on some pretty wild angles, but never pulling stumps like that...
Scrap yard goodies !
By BaronJ in forum METALWORK GENERALReplies: 7Last Post: 6th Jul 2019, 09:36 PM -
Scrap yard Mill
By Metalman in forum METALWORK GENERALReplies: 0Last Post: 12th Dec 2016, 06:56 PM -
If you go to the junk yard..
By sossity in forum GENERAL DISCUSSION / OFF TOPICReplies: 4Last Post: 24th Nov 2016, 09:09 AM -
lifting and moving heavy things
By morrisman in forum METALWORK GENERALReplies: 5Last Post: 29th Mar 2013, 06:40 PM -
Interstate couriers for small items too heavy for AU post
By .RC. in forum METALWORK GENERALReplies: 24Last Post: 14th Dec 2010, 07:37 PM
