Results 31 to 45 of 76
7th Sep 2019, 11:58 PM #31
10th Sep 2019, 07:07 PM #32Philomath in training
- 6,541
Not sure whether you are still looking or if this is too pricey but thought it may be of interest.
https://www.machineryhouse.com.au/K088
there is a cheaper version but it has a girder clamp rather than trolley
https://www.machineryhouse.com.au/K090
10th Sep 2019, 07:24 PM #33Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
10th Sep 2019, 07:30 PM #34Most Valued Member
- 2,651
Following on from the ideas here has turned up something that will hopefully be a good solution. I'll have more info on the weekend
14th Sep 2019, 11:18 AM #35
Hi Baron, I had done exactly that, rotated, resized and saved on computer before posting, which is why I apologised for them being lazy when they uploaded. Didn't used to be a problem with the same camera and win XP or Win 7 and software that ancient, seems to be with new computer, win 10 and current gen software. Same camera and USB connection etc so I guess it's the software preserving more data or something. Need to do some more research.
14th Sep 2019, 11:24 AM #36
Don't know if you are interested in this, but my first suggestion was the H&F 1T portable gantry, later linked to by Michael G. This weeks Weekly Times had the H&F Feildays specials catalogue with Michael G's first link reduced to $935 on page 5. Coupon Code for online order is FDAYS19 valid until 13/10/19.
14th Sep 2019, 03:30 PM #37Most Valued Member
- 2,651
Thanks, but I think I've found a solution
4WD, rear steer, powered by a 2cyl air cooled Lister diesel.
Was a small construction tipper in a prev life - likely 1970's.
Most importantly, I had management approval prior to buying it
14th Sep 2019, 04:30 PM #38Most Valued Member
- 5,942
That looks just the ticket, any idea as to lifting capacity? Not to be nosy Steve, but what it set you back???
Take Management out to tea or something even worse???
14th Sep 2019, 05:59 PM #39Most Valued Member
- 2,651
Not sure as to lifting capacity, but the guy I bought it off was using it to lift/drag cars around in a paddock and pull engines etc.
Cost me $1600 and a commitment to management that I reduce the "dead" vehicle count by two.
14th Sep 2019, 06:48 PM #40
14th Sep 2019, 07:19 PM #41Most Valued Member
- 5,942
Steve, that's a good price for the lifter, but the other to me, would be a hard pill to swallow, having to get rid of 2 of your treasures!!!!
14th Sep 2019, 07:27 PM #42Senior Member
- Perth, Western Australia
- 67
- 362
Nice piece of gear there Steve.
The attachments you could make for doing those jobs around the yard and garage.
Tony
14th Sep 2019, 07:44 PM #43Most Valued Member
- 2,651
14th Sep 2019, 08:00 PM #44Most Valued Member
- 2,651
You read my mind!
A leveling frame/blade to keep her driveway manicured, forklift mast, tipping bucket to load the ute with...
Amazing what becomes possible once you have mobility and hydraulics!!!
First things first though. I need to sort out the 3/4 of a turn free play in the steering box. Makes directional control "interesting".
Particularly when you mistakenly select third gear instead of first. Given the lug tyres on it I was quite surprised when it spun the LHF wheel as it bolted forward with me flailing the steering wheel around trying to get it to point where I wanted. Guessing it's got a massive flywheel as it didn't stall.
Lesson learned - fwd left is high gear, fwd right is first.
14th Sep 2019, 08:36 PM #45Diamond Member
- Jun 2010
- Canberra
- 1,322
Scrap yard goodies !
By BaronJ in forum METALWORK GENERALReplies: 7Last Post: 6th Jul 2019, 09:36 PM -
Scrap yard Mill
By Metalman in forum METALWORK GENERALReplies: 0Last Post: 12th Dec 2016, 06:56 PM -
If you go to the junk yard..
By sossity in forum GENERAL DISCUSSION / OFF TOPICReplies: 4Last Post: 24th Nov 2016, 09:09 AM -
lifting and moving heavy things
By morrisman in forum METALWORK GENERALReplies: 5Last Post: 29th Mar 2013, 06:40 PM -
Interstate couriers for small items too heavy for AU post
By .RC. in forum METALWORK GENERALReplies: 24Last Post: 14th Dec 2010, 07:37 PM
