Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: MH-28V Mill
  1. #16
    6,475
    Hi Rusty, Thanks for the picture.
    Obviously mine is much earlier than yours. Looking at the picture of the spindle on yours mine doesn’t stick out as much. Certainly much better than sticking a bit of rod in to stop the spindle turning whilst removing tools from the taper.
    This is mine. The bottom of the spindle isn't very clear and that collet chuck is the one that was supplied with the machine. I've removed the cover over the motor so I can keep an eye on it. I've also fitted a fan in the back of the cover to blow air over the motor. The little fan blades on the armature don't really shift much air at all.
  2. #17
    Jun 2010
    Canberra
    1,322
    Yep, I think Optimum have revised their designs over the years.
    Apart from getting some proper tooling and a vice sorted out, my next major step is adding a DRO. Optimum do a wonderfully simple magnetic DRO setup where you attach adhesive-backed magnetic strip to each axis and install corresponding readers, then hook it up to their DRO unit. However I'm kind of committed to doing a TouchDRO setup which uses an Android tablet for the DRO display, and requires conventional glass scales.
    In the meantime, I am learning how to zero the crank dials and count my rotations, something I bypassed with my lathe that arrived equipped with a DRO.
  1. Hercus o mill Vertical mill head lubrication
    By china eyes in forum THE HERCUS AREA
    Last Post: 14th Oct 2018, 06:57 AM
  2. Selecting a small Mill / Mill/Drill
    By Wombat200 in forum METALWORK GENERAL
    Last Post: 15th Mar 2012, 10:58 PM
  3. Arboga EM825 mill vs Hercus model 0 mill?
    Last Post: 14th May 2011, 03:16 PM
  4. Face Mill V End Mill
    Last Post: 31st Aug 2010, 03:19 AM
  5. No. 0 Mill Serial Number and Mill at Work Photos
    By Anorak Bob in forum THE HERCUS AREA
    Last Post: 30th Dec 2008, 03:31 AM
