Results 1 to 15 of 15
Thread: How to make a fan blade?
2nd Sep 2019, 11:12 PM #1Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,844
Anyone ever needed to make a fan blade? I need one for my small home built compressor but the catch is i have dogs and when i loan it out kids may be around the air compressor, is there some way of making a fan blade so it will turn under normal conditions but if someone or something stops the blade like little fingers or a dogs tail or paw that the blade will stop turning? Need ideas
3rd Sep 2019, 12:16 AM #2Senior Member
- Nov 2012
- Mid North Coast NSW
- 423
Only thing you can do is put a cage around the fan.
3rd Sep 2019, 12:27 AM #3Most Valued Member
- Aug 2009
- 1,844
Yeah that is a lot of work Phaser i dont have any material either i was thinking i could float the fans bushing on the shaft and some how link the fan blade to the shaft by very weak rubber bands so if there is any tesistance the bands will break
3rd Sep 2019, 03:29 AM #4Member: Blue and white apron brigade
The angular momentum of a full size set of blades blades is still going to bite unless the blades are made out of something like foam rubber and then are not really going to work very efficiently.
A better approach would be to use something like multiple small soft plastic drone blades. These blades will sting but won't cut skin.
Mythbusters did an episode on this showing it takes a big drone blades to cut skin.
However, by they time you set up 4 such blades I reckon you might as well just build a decent guard for a full size blade. A bit of sheet metal, a few brackets and some chicken wire is all that is needed.
3rd Sep 2019, 03:52 AM #5
Could a loose "o" ring drive be adjusted enough to just barely drive the fan coupled with a light weight cardbooard blade?
3rd Sep 2019, 06:59 AM #6Most Valued Member
- 2,672
How big is the compressor Gazza? Would the likes of a larger diam (125mm) electric equipment cooling fan be enough airflow? They are shrouded around the outside and if mounted close to the compressor head would only need a grille over the outside.
3rd Sep 2019, 08:17 AM #7Philomath in training
Trouble is, a fan blade with some sort of slip device is normally not smart enough to tell the difference between needing to slip because a finger is present and not slipping because it has to move air.
If you are going to all this trouble to make a dinky compressor to loan to people, why is building a guard too much effort?
3rd Sep 2019, 10:11 AM #8Most Valued Member
- Aug 2009
- 1,844
Yeah i think it may be a wild idea trying to make the slipper fan i will try make some sort of cage just need to find suitable supplies
3rd Sep 2019, 11:28 AM #9Golden Member
- Cairns, Q
- 666
How about buying a cheap fan, maybe something like this:
https://www.ebay.com.au/p/Heller-HHD...iABEgJy9vD_BwE
to get a ready made cage. You might even be able to use the blades, though I doubt there would be enough material in the hub.
Frank
3rd Sep 2019, 12:51 PM #10Most Valued Member
- Aug 2009
- 1,844
I thought about buying this fan https://www.ebay.com.au/itm/CONDENSE...sAAMXQVT9SvPI2 but at $60 it is quiet expensive than i need to buy a billet of aluminium to turn on the lathe for the center of the fan to bolt to plus the cage it will all be adding up in cost
3rd Sep 2019, 01:10 PM #11Most Valued Member
- Healesville
- 2,129
A lawn mower flywheel and cowling would do the trick, depending on size of the pump?
If it is smaller then maybe a the same parts from an old brush cutter could fit.
Try your local mower shops as they normally have a spare parts pile of old stuff that is not worthwhile reparing.
cheers, shed
3rd Sep 2019, 01:57 PM #12Novice
- Sep 2014
- Elimbah Qld
- 24
Water cool it then water the garden at the same time
3rd Sep 2019, 03:30 PM #13Senior Member
- Jan 2011
- shep Victoria
- 97
- 157
How to make a The simple and safesfan blade
The simple and safest way is to put the compressor in the kids play pen and the compressor will be perfectly safe from every body.
3rd Sep 2019, 03:32 PM #14Most Valued Member
- 2,672
https://www.ebay.com.au/itm/Vintage-...kAAOSwfbhbzQSo
Maybe pick up something like this??
4th Sep 2019, 12:57 AM #15Senior Member
- Nov 2012
- 423
or 20 bucks for a brand new exhaust fan from Bunnings. Will need to box in the motor and wiring though.
Bi-metal Blade
By grunto in forum METALWORK GENERALReplies: 16Last Post: 5th Mar 2015, 10:13 PM -
Jig saw blade help
By lemon2 in forum METALWORK GENERALReplies: 1Last Post: 17th Feb 2012, 04:02 PM -
Abrasive cut off blade
By lukejj in forum METALWORK GENERALReplies: 2Last Post: 26th May 2010, 09:03 PM -
Blade for Bandsaw
By John H in forum METALWORK GENERALReplies: 5Last Post: 17th Jun 2008, 06:40 PM
