Results 1 to 15 of 21
Thread: Building a vise post
23rd Aug 2019, 08:24 PM #1
I bought a half decent vise.
Need to mount it, bench space is at a premium, so thinking I'll weld a post to an old truck drum brake I've got and mount it like that.
The model I have has a swivel base design, with pipe clamp, and it also rotates to access that function.
What height do people recommend? I've heard a few inches below elbow height. I want this to be a bit of a semi-mobile work station.
23rd Aug 2019, 09:23 PM #2Most Valued Member
I'd set the jaws of the vise at elbow height. If you find it too high, then you can always trim a bit off.
I've set my vise on a piece of plate welded to 50mm RHS, that slides inside a piece of 65X65X6RHS, (similar to a Hayman Reese towbar setup), welded to the side of the bench. That way I can remove it if I need more bench space, or fit a bar bender, another grinder, leaving many options available.To grow old is mandatory, growing up is optional.
23rd Aug 2019, 10:02 PM #3Member: Blue and white apron brigade
Another alternative/option might be to make it height adjustable?
25th Aug 2019, 08:19 PM #4
Knocked this up today.
Used an old truck drum brake, some scrap 75x40x5mm RHS, and a few bits of plate I picked up from a scrapper in my travels.
Overall height to the top face of the jaws is 1030mm. ie approx 40mm lower than my elbow height when bent 90 degrees.
Works well! Great height for filing, and will interface as an extended surface off my work bench.
26th Aug 2019, 07:36 AM #5
I was getting Keen building it over the weekend, and decided I'd drill and tap some M10 8.8 bolts into the plate to make her hold (and make removal a little easier).
Something got lost in translation, and 2 of the 4 holes were off by a bit.
So I welded up the offending holes, and re-drilled, however my HSS bits were not up to task. Had some good success with the Cobalt VIPR bits from Sutton. But had even better success with the Titanium nitride bit supplied in the Sutton handy packs containing a drill and matching tap.
This justified a new tool purchase- transfer punches are on order. I have made this mistake way too many times now, when the drill bit wanders and I lose the game by a fraction of a mm.
26th Aug 2019, 11:10 AM #6Member: Blue and white apron brigade
26th Aug 2019, 06:54 PM #7
About 2mm out. I think this was a compound error as each hole wandered a little and it converged on the last hole to make it unworkable. I didn't want to file or drill out the vise base, and didn't want an oval hole to tap, although it probably would have been OK for a hack like me.
My shed is a corrugated iron box. In summer temps of 50 are not uncommon. The dirt floor work area used to have a horrendous aviary on it, and while a dirt floor, has a bit of breeze and shade all around. I should really get around to cleaning up all the loose dirt and putting down something a bit more firm. Moving gas bottles over it is a right pain in the tuchus.
26th Aug 2019, 07:51 PM #8Most Valued Member
- 70
- 1,514
I have attached my vice to a length of PFC. This is shaped to fit on a 3" square pergola post via a 16mm bar through the post and another bar through the PFC to seat against the face of post. Two vertical slots for the 16mm bar in the sides of the PFC and holes through the PFC for the 12mm bar against the post. Just insert the 16mm bar, slide on the table and put the 12mm bar in. Quite sturdy but I would like to add maybe an over centre latch to lock it down firmly.
Nev.
27th Aug 2019, 07:41 AM #9
Gotta pic nev?
27th Aug 2019, 07:43 PM #10Most Valued Member
- 70
- 1,514
1st Sep 2019, 08:05 PM #11Most Valued Member
- 70
- 1,514
Pics.
Nev.
1st Sep 2019, 08:09 PM #12
Hi Nev,
Very posh, looks nice !Best Regards:
1st Sep 2019, 08:34 PM #13
Is it just the angle of the slot that stops it dropping straight down?
1st Sep 2019, 09:03 PM #14Member: Blue and white apron brigade
Nice job Nev.
99% of the time the forces on a vice are across or down but sometimes it is upwards
To counteract that and to tighten the vice onto the post what about something like this?
Weld a steel tab with a threaded hole in it and add a bolt to lock the shebang to the post?
2nd Sep 2019, 05:54 PM #15Most Valued Member
- 70
- 1,514
Vise grips
By Big Shed in forum METALWORK GENERALReplies: 2Last Post: 14th Feb 2015, 10:06 AM -
Post Vice, are a vise
By DSEL74 in forum THE SMITHYReplies: 6Last Post: 27th Jul 2014, 08:03 PM -
What do you think of this vise?
By FenceFurniture in forum METALWORK GENERALReplies: 31Last Post: 26th Jun 2014, 08:28 PM
