Results 1 to 5 of 5
Thread: Help identifying type of collet.
22nd Aug 2019, 10:45 PM #1Golden Member
- Jul 2011
- 837
I came into a bunch of collets today. Round, Hex and Square. I am looking for a collet chuck to suit but I have no idea what designation these collets are. Can anyone help? Overall length is 3.785" diameter at widest is 1.6" and at the other end 1.125"
Thanks in advance.
23rd Aug 2019, 12:22 AM #2
Hi Eric,
They look similar to the ones that used to be used on a capstan lathe, where the collet was held closed by a rotating cone and a lever was used to operate it. But from memory the tool holder on the capstan was only 1" inch bore.Best Regards:
23rd Aug 2019, 01:15 AM #3Most Valued Member
- 5,945
Hi Eric,
I'm pretty sure that your collets are for a Ward Turret Lathe. They go in the headstock, where a lever is used to loosen the collet, the bar is advanced by weighted pulleys, the collet tightened and material turned, parted off and the process repeated.
Sort of a Manual CNC machine.
BJ, the collets don't go in the tool turret head.
HTH
23rd Aug 2019, 06:33 AM #4
Hi Kryn,
Thanks for your post, yes it was a Ward 5A that I remember, but that was over 50 years ago. There was a handle maybe a foot long that was pulled and pushed to rotate a collar. I recall been intrigued by the mechanism.Best Regards:
23rd Aug 2019, 09:38 PM #5Most Valued Member
- 5,945
I had 3 Wards about 20 years ago. Picked up another one recently for $200.00 no tooling though. Should be easy enough to make the holders.
ER UM Type Clamping Nut For Collet Chuck
By wm460 in forum METALWORK GENERALReplies: 3Last Post: 17th Oct 2016, 12:47 AM -
Changing collet type - obscure to common
By jhovel in forum METALWORK PROJECTSReplies: 5Last Post: 3rd Jul 2016, 12:09 AM -
Type A and Type B assets - Grays online
By simonl in forum METALWORK GENERALReplies: 38Last Post: 1st Oct 2014, 11:04 AM -
Collet type comparison
By WCD in forum METALWORK GENERALReplies: 5Last Post: 10th Nov 2013, 03:35 PM -
SOLD: ER32 Collet Chuck (Backplate Type) For C2 Lathe
By SurfinNev in forum METALWORK - Machinery, Equipment, MARKETReplies: 11Last Post: 21st Aug 2011, 09:51 PM
