Results 16 to 30 of 100
19th Aug 2019, 07:25 PM #16
Maybe an optical illusion but in the first pic I can see a curve in the belt where it leaves the small pulley.
If so belt is too loose. Not sure why it has a problem turning if you tighten it but keep working on it to get it right, that compressor will be much better than the direct drive ones.
19th Aug 2019, 07:36 PM #17Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,836
Droog u are correct mate this belt is a dunlop belt i went to Pilot Airs service center in Sydney shortly after i bought the compressor i took in the old belt and the bloke who served me took the money than said he had to go down the road to get the belt he came back 20mins later with this belt, pilot air has 2 factories 1 street apart so he may have gone to the other factory but i must say this belt is quiet stiff from day 1
19th Aug 2019, 07:40 PM #18Member: Blue and white apron brigade
- 7,183
CRC belt grip spray. ~$20 at supercheapauto
https://www.supercheapauto.com.au/p/...400g/1444.html
It makes a surprising difference.
19th Aug 2019, 08:08 PM #19Most Valued Member
- Aug 2009
- 1,836
Comp is running a dunlop match vee belt i just went out to the shed to check the play between pulleys its about 15mm possibly 20mm i read the recommended is 10-12mm so i think the compressor may be fixed
I will first try to tighten the belt the tinest movement if that fails i will get a can of that magic
This is my first electric belt compressor my only other belt compressor was a hafco 100L honda petrol powered compressor and that thing i could run a dust gun at 90psi continously for as long as i wanted so u can imagine when i hear my little pilot air compressor it just sounds weak like no omph to it
19th Aug 2019, 08:12 PM #20Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
Looking at the video and the picture the belt sorta looked like it was a blue colour, which if it is then it's most likely a kevlar belt which are stiffer than your average black rubber belt and unsuitable for an air compressor. (kevlar belts do come it some other colours). You shouldn't need a cogged belt unless the motor pulley is 3" and below. The belt is definitely too loose, all the same I would try another belt as it sounds like it's too stiff if the pulleys won't turn when it's tightened.
All The Best steran50 Stewart
20th Aug 2019, 01:15 AM #21Senior Member
- Perth, Western Australia
- 67
- 362
Go with a new belt. Full V section, gives more contact area.
Make sure the pullies are in line. Use a straight edge.
Don`t over tension the belt. Too much load on the motor or comp bearings will damage them.
CRC belt grip, great diagnostic tool. For multi belt setups it was great for spaying some on each belt until you find the noisy one. Handy but not a long term solution.
Tony
20th Aug 2019, 01:29 AM #22Senior Member
- 67
- 362
Forgot,
Can you take a pic of the motor drive pulley looking down into the V section. The belt appears to be sitting low in the pulley, might be worn after years of squealing.
Tony
20th Aug 2019, 03:01 PM #23Most Valued Member
- Aug 2009
- 1,836
The compressor is finally fix and works awesomely finally lol, i had to jamb a piece if 50x50mm alloy in between the motor and pump to push the motor a part to get the correct tension on the belt, i ran my hose directly to the tanks outlet no extra fittings or joints just strait to a barb fitting i put a new fitting on the end of the hose and everything is air tight except there is a very tiny leak from the one way valve where it screws into the tank i need to address also the copper air delivery hose was originally bent when i bought the compressor and yesterday i kinked it more than bent it back a little and it put a small 1mm hole in a crease it only leaks when it is filling up can i use ordinary electrical solder? i tried to use one of those fan dangle low aluminium welding rods to fill the hole but its crap
also think my pulley on the motor is worn will upload pictures
time to fill up a tank from empty is 3mins 15sec, time to top up a tank from cut in to cut out is 1min, i get 25 seconds of free air thru a air duster gun at full 145psi
i changed from PVC 3/8" hose to 1/2" high quality thick but soft air pressure hose
loving life now have a awesome air compressor now i just need a air receiver for more volume for when i sand blast
https://www.youtube.com/watch?v=zDVXLZeoca8
20th Aug 2019, 04:44 PM #24Senior Member
- 67
- 362
Glad to see you got it going.
Try some solder on the pin hole.
Before adding a receiver tank try out your sandblasting set up. The tank will give more run time but will require more fill time. Frustrating to say the least.
Tony
20th Aug 2019, 04:54 PM #25Most Valued Member
- Aug 2009
- 1,836
Here is that little hose pinch fitting that i had to fabricate for the pilot hose fitting made on the lathe i first tried to make one from a mig welding tip but the brass was to soft in the lathe so whizzed it up out of a 6mm bolt
Loth the lathe
The other picture is the delivery hose and pulley
20th Aug 2019, 06:21 PM #26
Hi Gazza, Guys,
It looks like the belt has been riding on the bottom of that pulley.
Indicating a worn belt or a worn pulley or both.
As far as the nick in that copper tube is concerned a cooks torch and cored solder. Give it a good rub with a scouring pad first to get it clean. Or Bakers fluid on a cotton bud. Don't let bakers fluid get inside the pipe though.Best Regards:
20th Aug 2019, 06:46 PM #27Senior Member
- 67
- 362
Have to agree with BaronJ, looks like its rubbing on the bottom of the pulley.
From one of mine you can see the bottom and a small section of the sides are untouched.
The outer of the belt will not always sit this flush with the outer of the pulley but should be no more than a couple of mm inside. Yours does sit a fare way down inside the pulley.
I have got away with machining some out of the bottom of a pulley before. Just a temporary fix until I could find a new pulley.
Tony
20th Aug 2019, 07:31 PM #28Most Valued Member
- Aug 2009
- 1,836
By the looks of your pulley to mine mine is well worn I'm also assuming if the smaller pulley increased in diameter it would increase the pumps rpm is this right?
20th Aug 2019, 08:22 PM #29
Increasing size of small motor pulley will increase pump speed, but will also increase motor load and can cause the motor to stall or cook itself.
Also need to check the recommended rpm for the pump, too fast will cause excessive wear.
The top of the copper tube looks like it has been twisted and will have weakened it, I woul get it replaced, simple job with a plumbers flaring tool.
What is you intent with regard to blasting? Blasting requires lots of air, and I mean lots. You may be disappointed if you intentions are much above small parts.
20th Aug 2019, 08:37 PM #30Member: Blue and white apron brigade
- 7,183
The pulley looks like it's ~3mm into the V.
For a 100 mm diameter pulley that's about 6% smaller so the rpms will be 6% higher, for a 1440 rpm motor that is about 86 more RPM, probably not going to make a lot of difference to the compressor but its still worth fixing for other reasons discussed.
Oil less air compressors.
By tohot in forum METALWORK GENERALReplies: 16Last Post: 22nd Sep 2018, 09:11 AM -
Air compressors - a comparison table of 16 models of 3hp 15A types on the market
By Gunnaduit in forum METALWORK GENERALReplies: 11Last Post: 14th Jul 2018, 10:45 AM -
Do conventional compressors have a direction?
By BobL in forum METALWORK GENERALReplies: 17Last Post: 17th Jun 2014, 08:17 PM -
Are two compressors are better than one?
By Ben Dono in forum METALWORK GENERALReplies: 15Last Post: 19th May 2014, 10:49 PM -
Thoughts on plasma cutters with built in compressors
By Michael G in forum WELDINGReplies: 6Last Post: 2nd Nov 2013, 07:13 PM
