Results 1 to 10 of 10
    Jul 2006
    Athelstone, SA 5076
    4,258
    Default Bronze bushes - split. (2 halves)
    Does anyone know where one can get 12x16 split bronze bushes?. Cant seem to find anyone via google. Lots of non split.
    6,477
    Hi Eskimo,
    You might have to make them !
    Buy a smaller size bore, split them, clamp them together and bore to size.
    I made some from two pieces of solid. Worked out OK.
    6,477
    Hi Eskimo,
    Did you find a solution to this problem ?
    Jul 2006
    Athelstone, SA 5076
    4,258
    Hi Eskimo,
    not as yet, but am thinking I might make them this way..
    softsolder two bit of bronze together.
    Turn to size OD and ID and length
    un-sweat ?
    at the speed I work you guys have plenty of time to think up other ways and to let me know
    this is for the Stewart Hart overcrank engine I am making
    attached are drawings that Stewart sent me....note some dimensions are incorrect..eg crank eccentrics show 10mm dia hole...should be 12...so double check
    Potty Over Crank.pdf
    if anyone wants to make a bigger one I do have drawings for that as well
    can anyone explain why its called and Overcrank engine
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    That's the way I've heard it done and the way that I would be trying first
    Mar 2014
    South of Adelaide
    1,227
    un-sweat ?
    That's how we do them at work, but we use low melt silver solder.
    Feb 2009
    jilliby nsw
    111
    Hi Eskimo, that's an interesting looking engine judging by the plans. I'm looking for a next year project. Is there a picture of the completed engine by any chance. Looks like there are no castings involved or at least I didn't notice any. How far into the construction are you? Could you possibly email me the plans if their not copyrighted? How much bigger is the larger one?
    6,477
    Hi Ian,
    This link might be of interest.
    https://plans-for-everything.com/hen...ine_plans.html
    Lots of interesting engines to play with. I think the potty overcrank engine is on there as well.
    Apr 2012
    Healesville
    2,129
    Make bush from pb barstock in lathe, leave bush on bar and put in mill and machine flat to centre of bush, put back in lathe and part off, repeat proceedure.
    shed
    Jul 2006
    Athelstone, SA 5076
    4,258
    Quote Originally Posted by hpa1 View Post
    base and bearings mounts made...still a long ways to go...and yep no castings
    here is Stewart's model on youtube
    Stewart's has a governor and there is another on youtube without the governor
    The plans I attached in the post above are what Stewart sent me....you should be able to save that as a file.
    This is the Julius De Waal one that he basically copied from Stewart Hart's plan and scaled up...bout twice the size of Stewart's
    JDW over-crank engine stewart-hart-09-05-12.pdf
    Julius has a lot of other model drawings freely available on the net...here... www.vapeuretmodelesavapeur.com
  1. Bronze Bushes
    Last Post: 25th Nov 2015, 08:52 PM
  2. Making Bronze bushes
    By simonl in forum METALWORK GENERAL
    Last Post: 7th Aug 2015, 11:36 PM
  3. Reducing size of bronze bushes
    By JillB in forum METALWORK GENERAL
    Last Post: 26th Jan 2011, 12:16 PM
  4. Replies: 12
    Last Post: 18th Jul 2009, 12:40 PM
  5. worn bronze bushes
    By burraboy in forum METALWORK GENERAL
    Last Post: 16th Aug 2007, 07:41 AM
