Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 51
  1. #31
    Aug 2009
    Sydney, NSW, Australia
    1,844
    This is my pump Bob i'm not sure if its single or dual piston but its a 1.six5kw motor it doesnt say what oil to use https://www.pilotair.com.au/wp-conte...ET-UPdated.pdf
    Baron ugot an absolute deal on that electric die grinder lucky bugger!
  2. #32
    6,475
    Baron u got an absolute deal on that electric die grinder lucky bugger!
    Thanks Gazza,
    I bought it to replace the Dremal style grinder that I use as a toolpost grinder.
    Another of those round toit jobs
  3. #33
    Aug 2009
    1,844
    Bob the Pilot Air web site recommends ISO 100, ISO 150, the oil i am running in the pump is ISO 68 i will look into what those numbers mean but can u elaborate a bit on where i am going wrong with the oil? to thick to thin etc?..
    Thanks Gazza,
    I am always stripping screw heads and bolt heads mate so this nifty little die grinder can either reshape a bolt head to grab it with pliers or grind it off for welding its the best little tool i have needed for a long time just wish it was portable with a very long lasting battery but that's a wish lol
  4. #34
    Aug 2011
    Perth, Western Australia
    67
    362
    Gota love pnumatic die grinders. I would not be without them.
    To run even a small die grinder you need at least 10 cfm (free air delivery. Not to be confused with piston displacement that manufactures use to quote their compressor sizes).You can get away with less but then you are waiting a lot of the time for thecompressor to catch up. I`ve got 20 cfm and that keeps everything running nicely.
    I use to have an electric die grinder for site work as air was not always available but some A-hole liked it better than I did. Hitachi, I still rate these as the best electric on the market. Never did replace it.
    I still have a Dremel, they have their uses but they are really only a toy.
    With bits, if your doing a lot of alley single cut aluminium bits (not to confused with single cut steel bits) are the way to go. I usebee`s wax as a lube. With steel (brass or what ever) double cut are the way to go. They do not bounce around as much and remove more material.
    In pic LHS bit is single cut for ally, Very course. RHS is double cut
    Back in the days when I use to service compressors 30 wt was pretty much the standard oil to use. Iso 68 if we had nothing else. I have been using 15W40 diesel engine oil (same as my ute) for 20 years now, never had aproblem.
    Tony
  5. #35
    Aug 2009
    1,844
    When i had 90psi at the tool from the 10.8cfm compressor the die grinder knocked the peek off that 90psi really fast probably 8 seconds are u can hear the speed slow down but it still remains powerful for around 25 seconds than it just sits at a fast pace and tapers off in power i found it jumped around at the lower rpm/psi range but was easier to control the cut, at full power it was way to easy to gouge
    I have some diesel oil i might try that tomorrow i looked up the oil i have 68 in it which is thinner viscosity than the 100 and 150 the manufacturer specify so i cant explain why the pump is struggling, one would think thinner oil less drag unless the oil 'floats' the crankshaft and it may be binding with the thinner oil? Possibility
  6. #36
    Aug 2011
    67
    362
    I could not find any actual flow figures for your compressor but I am thinking that 10.8 cfm is piston displacement.
    The old rule of thumb use to be 3/4 of piston displacement would give you roughly an air delivery figure.
    Also with a 1.65kW motor I`d expect this to be supplying about 7cfm @ 90 psi.
    This would explain why the grinder speed is dropping off so quickly.
    Are there any air flow figure given in the instructions that came with the grinder?
  7. #37
    Aug 2009
    1,844
    I dont actually have a regulator to see the psi there is a gauge on the tank and i remember having a regulator at the end of the hose previously and it was reading around the 90psi mark maybe 95psi
    I just checked the manual it says 128 litres per minute i have about a 50-60 litre tank plus i have the tinest grinder nick in my hose so a cery small portion is leaking from the hose nothing major just like a leaking fitting
  8. #38
    Aug 2011
    67
    362
    Ok,
    Tank size is irrelevant. With a larger tank it takes longer before the comp starts but it also takes longer to fill.
    At the end of the day what goes in is what comes out.
    "plus i have the tinest grinder nick in my hose so a cery small portion is leaking from the hose nothing major just like a leaking fitting"
    You would be surprised how much air is lost through a small leak.
    A good test is leave the compressor fully charged and off to see how much it leaks down. (A good comp should take days if not weeks to bleed right down). Then plug your line back in and see how long it takes to bleed down.
    128 l/min, about 4.5 cfm. I`ll assume (not a good thing) that this is what`s called its average air consumption. Actual air consumption at load will be at least twice this figure. If those figures are correct that makes an economical grinder. My small CP pencil grinder uses nearly that much. Wander what the watt rating is for the Ryobi?
    Tony
  9. #39
    Oct 2008
    Cairns, Q
    666
    Quote Originally Posted by bts View Post
    Looks like you guessed about right. The data panel here:
    https://www.pilotair.com.au/product/...ors-tm-series/
    quotes Piston Displacement 10.7 cfm and FAD as 6.5 cfm and maximum pressure 145 psi. It doesn't specify the pressure at which the 6.5 cfm is delivered, so possibly at 145 psi? It does say performance measured to AS4637. Does the standard specify the pressure at which FAD is delivered?
    Frank
  10. #40
    Aug 2009
    1,844
    Guys the Pilot Air Compressor is just not panning out i have owned it for a few years now probably about 5 years i think its time to cut my loss and buy another air compressor, Today i changed the oil to ATF i aligned the belt and pulleys but its still making that sequel and the up and down revs and it almost stalling before hitting air cut off point than speeding up again out of no where to top it off i just snapped my plastic pvc hose in 3 pieces
    about to look online for one or possibly 2x 50 litre compressors to link together
  11. #41
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Maybe the compressor valves are leaking, could be a cause of your semi stalling.
  12. #42
    Aug 2011
    67
    362
    Does the belt have a smooth shine to it? New belt may be in order.
    Generally the finger valves on the compressor don`t offer to many problems. Though pulling them out can give a chance to clean them up for better sealing, without having a set a gaskets on hand I would not go there.
    In the air line from the comp to the tank there should be a non-return valve. Depending on the type I have had problems in the passed with these sticking leaking air back and loading up the compressor.
    Keep going with this one. Get it going and then buy another to give more air. You will need the money saved on buying two for the bits you need to connect two together and get the best out of them. That and the new air tools you will want to buy now you have the extra air.
    Tony
  13. #43
    Aug 2009
    1,844
    I blocked off the snapped hose and powered up the compressor and got a video of it
    https://www.youtube.com/watch?v=g5FU9XpgIw4
    i pulled the one way check valve a part and it seems one of the seals above the button inside the valve had perished i blew thru the valve with my mouth and it seemed to work ok even with the perished seal
  14. #44
    Aug 2011
    67
    362
    I keep meaning to ask, do you have a pressure gauge mounted somewhere to see at what pressures the comp is cutting in and out at and at what pressure things start to go wrong.
    Tony
  15. #45
    Aug 2011
    67
    362
    I`m afraid blowing through it does not mean much. Remember 145 psi takes a lot of stopping.
    Just watched the vid. Sounds like the compressor is battling head pressure. Replace the seal in the non-return valve and see how it goes.
    Tony
  1. Cheap Protection from Super Cheap.
    Last Post: 30th Apr 2014, 12:01 AM
  2. Home Made Surface grinder Auto Feed
    By steran50 in forum METALWORK GENERAL
    Last Post: 17th Aug 2012, 08:04 PM
  3. Super Cheap auto inverter welder
    By RVK 355 in forum WELDING
    Last Post: 10th Mar 2012, 10:23 PM
  4. Cheap vices at Super Cheap Auto
    By LordBug in forum METALWORK GENERAL
    Last Post: 5th Jun 2011, 01:14 AM
  5. Cheap Auto helmets and low amps
    Last Post: 2nd May 2010, 11:28 PM
