Results 1 to 8 of 8
    Oct 2006
    Newcastle
    124
    Default Grinding wheel dressers
    Apologies if I've posted this in the wrong spot, but I'm after some feedback etc on grinding wheel dressers, similar to the one in the link
    https://www.banggood.com/Sintered-Di...r_warehouse=CN
    Hafco AL320G Lathe
    Toolex RF31 Mill/Drill
    Saber Bandsaw
    Nov 2009
    australia
    57
    There quite OK for a few dressings, but the moment you wear thru that coating, then your going to need another real soon.
    This type of dresser is a bit better and will last a lot longer, which will work out to be the cheapest in the long run.
    Not saying to buy that one in the link, just go for that type of dresser.
    https://kutritemfg.com/dressers.php
    Aug 2007
    Saskatoon, Saskatchewan, Canada
    292
    I asked some guys using a concrete/road saw if they had any old blades. They gave me a few and I used a cutting disc in a grinder to cut wedges from the expansion slots in the edge to the hole. Wrap the heck out the point with duct tape or make a simple handle hammered over the point. One blade will give you a lifetime of dressing tools and a few for your pals.
    I also have a small rock drilling bit end, the kind used to drill core samples, given to me. It works great too. Bigger diamonds!
    Pete
    Dec 2005
    South Australia
    1,657
    That type of dresser works very well I have had one years, however the one one pictured does not spell high quality to me
    Oct 2006
    Newcastle
    124
    Quote Originally Posted by China View Post
    So which one are your using or recommend ??
    Hafco AL320G Lathe
    Saber Bandsaw
    Sep 2011
    Ballarat
    65
    3,103
    Hi oldhack
    I would absolutely recommend the one with the star wheels.
    Also when they wear out you can buy new star wheels...which reminds me.
    Phil
    Jul 2006
    Athelstone, SA 5076
    4,258
    anything wrong with diamond dressers?
    Mar 2014
    South of Adelaide
    1,227
    I use the type the op linked to at work. I have had it for about 5 years and on average would dress the 8" wheel we use for drill grinding twice a month. it shows no sign of wearing out any time soon, should be fine for use in a home shop.
  1. Grinding Wheel
    By Oldneweng in forum METALWORK GENERAL
    Last Post: 15th Jan 2017, 06:07 PM
  2. Ebay Diamond wheel dressers
    By argeng in forum METALWORK GENERAL
    Last Post: 17th Aug 2012, 11:08 PM
  3. Anyone qualified to compare wheel dressers?
    By billrule in forum METALWORK GENERAL
    Last Post: 20th Jan 2011, 09:34 PM
  4. Replies: 14
    Last Post: 8th Aug 2009, 02:23 PM
  5. Lap grinding wheel
    By ROB NZ in forum METALWORK GENERAL
    Last Post: 20th Jan 2008, 06:42 AM
