Results 1 to 9 of 9
Thread: help with TC tool inserts.
4th Aug 2019, 09:33 PM #1
I have just about come to the last of my supply of TC inserts for one of my lathe tools.
These were sourced some time ago, and goggle seach only showed one result I could read (english), and all I got from that was that they are a chipbreaker insert and discontinued.
They are a SECO insert No: 117.16-631.
Anyone know of a equivalent tip I can use or a resource to research further. ?Hafco AL320G Lathe
Toolex RF31 Mill/Drill
Saber Bandsaw
4th Aug 2019, 10:50 PM #2Member
- Nov 2009
- australia
Get yourself some new decent tooling, those things went out when "Christ" was an ankle biter.
5th Aug 2019, 12:13 AM #3
Hi Oldhack,
That's a bugger, I've only just dumped my 2000 and 2010 Seco handbooks in the paper recycle bin ! That insert is not listed in my 2017 one and I'm just about to dump that one too. Way too expensive for me anyway. Give Seco a call and ask them, they will send you their latest hand book for free.Best Regards:
5th Aug 2019, 07:19 AM #4
5th Aug 2019, 08:29 AM #5Philomath in training
Google is suggesting to me that the equivalent these days is a TPUN insert. You would need to check that.
5th Aug 2019, 09:17 AM #6Senior Member
- Jun 2005
- Townsville, Tropical Nth Qld.
- 226
Google Carmet in Brisbane and give him a call, has been very helpful to me, he carries a lot of older stuff.
Rgds,
Crocy.
5th Aug 2019, 09:43 AM #7Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
For around $80 posted you can buy a new turning holder of a type that takes your fancy and a pack of 10 inserts (common easy to find inserts) to suit.
6th Aug 2019, 08:04 PM #8
Lately not being on insert tooling but having plenty of old quality ones I've taken gamble's on eBay and AliExpress tooling and bought a few.
One was a turning and facing tool with 10 inserts for around $28, thought it must be crap, but turns out a great tool and the inserts have 3 cutting edges and then they can be turned over and a fresh 3 cutting edges on the other side. Fantastic value and have cut plenty of different steels and stainless steel.
Same with a $27 4pc small boring bar set 6,7,8,10 bars from memory including 10 inserts, works absolutely great as well.Using Tapatalk
6th Aug 2019, 09:24 PM #9Senior Member
- Jul 2012
- Griffith NSW
- 435
Trick Turning and facing tool with TPG inserts
By topari in forum METALWORK GENERALReplies: 1Last Post: 23rd Apr 2019, 01:45 PM -
Where to buy inserts?
By Bidgee in forum METALWORK GENERALReplies: 6Last Post: 29th Nov 2010, 11:28 AM -
Plans wanted for Carbide Tip inserts tool holders
By Jors in forum METALWORK GENERALReplies: 11Last Post: 13th Nov 2010, 11:12 PM -
carbide inserts
By eskimo in forum METALWORK GENERALReplies: 1Last Post: 11th Jun 2010, 06:25 PM -
Help wanted for tungsten lathe tool inserts
By INVENTOR in forum METALWORK GENERALReplies: 19Last Post: 9th Feb 2009, 06:04 PM
