Page 1 of 4 1234 LastLast
Results 1 to 15 of 57
Thread: Welding HSS
    Nov 2012
    Mid North Coast NSW
    423
    Default Welding HSS
    Hi all,
    I need to make a tool for shaving out a gear keyway on the lathe.
    The keyway is 5mm in an 18mm bore.
    My plan is to stick weld a piece of HSS into the end of a round steel bar but I'm a little worried about affecting the HSS hardness.
    What should I do after welding it ?
    Jul 2016
    35
    1,522
    Could you braze or silver solder it instead? Neither of those will change the temper. I have never seen hss weeded successfully.
    Nov 2012
    Mid North Coast NSW
    423
    Quote Originally Posted by caskwarrior View Post
    I guess I could try silver solder, if my torch will get it hot enough. I've only got LPG.
    But then I'd have to get the HSS red hot for silver solder, wouldn't that change the temper ?
    7,188
    The temp of the HSS won't be affected by welding - that is if you can weld it but like CW says I have not seen it welded, brazed certainly.
    HSS has to be held at red heat for a long time to substantially affect the hardness and even then it only changes by a few points on the hardness scale.
    Annealing requires hours of heat.
    Jul 2016
    35
    1,522
    Quote Originally Posted by phaser View Post
    I regularly use a primus lpg torch to silver solder carbide but I have to use the high silver content and fire bricks. How big is the cross section?
    6,473
    I agree with Ralph, I've never seen it welded either ! Usually it is silver soldered or brazed with sifbronze.
    As far as cutting a keyway is concerned just use a grub screw to secure the HSS. Its a lot easier.
    Nov 2012
    Mid North Coast NSW
    423
    A grub screw was the original idea but how do you make a 5mm square hole through a 14mm round bar and on an angle ?
    I could drill it but it's a hell of a lot of filing to make it square.
    Apr 2012
    Healesville
    2,129
    316L stainless rods are good for welding hss to steel.
    Sometimes I also use them for welding cast iron, steel to cast iron, cast steel.
    cheers, shed
    https://www.boc.com.au/shop/en/au/bo...rodes#product1
    May 2011
    Murray Bridge S Aust.
    5,959
    It doesn't nessecarily need to be a square hole, as long as the grub screw is square to the face, that should be enough to hold it in position.
    6,473
    Hi Phaser,
    You don't !
    Just drill a hole in the end of a suitable piece of bar, fit your HSS bit into the hole and secure with a grub screw.
    Put the gear in the lathe chuck and the cutter in the tool post, use the lathe saddle to move the tool in and out to cut the keyway. You will need to grind the cutting face correctly and you will only take off a few thou per cut.
    Here is one I did earlier.
    I found that cutting more than one key slot very tiring, so I made a tool to help.
    This is the tool. There is just a grub screw to secure a length of suitable tool steel. In your case for a 5 mm wide key, use a 5 mm wide piece of tool steel.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Hi all,
    Use it.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Me too, I can't seem to find HSS weeds, but I have welded it and used it after welding with Mig and stick.
    Aug 2011
    4,779
    Hi Phaser,
    You don't !
    I have made several internal keyways using this same technique. I concur that it is a laborious task if you have to make several but as a one-off it still works very well. I really need to make one of those lever setups.
    Nov 2012
    Mid North Coast NSW
    423
    My idea was to weld or solder it in like this.
    A round bar about 12mm slotted with a hacksaw and files to take the 5mm HSS bit.
  15. #15
    near Rockhampton
    6,217
    A stronger way is to mill an angled slot in the holder lengthwise and put the HSS in there and grind to suit. I will get a photo of one I prepared earlier.
  1. oxy welding help
    By bobsreturn2003 in forum WELDING
    Last Post: 9th Jun 2011, 04:46 PM
  2. co2 for mig welding
    By wodstok in forum METALWORK GENERAL
    Last Post: 13th Jul 2010, 10:07 PM
  3. Welding gal
    By Groggy in forum WELDING
    Last Post: 10th May 2009, 11:00 PM
  4. Where do you do your welding?
    By jmk89 in forum METALWORK GENERAL
    Last Post: 13th Mar 2008, 01:42 AM
  5. new to welding.
    By Bluegum in forum WELDING
    Last Post: 24th Oct 2006, 09:22 PM
