Results 16 to 30 of 57
Thread: Welding HSS
3rd Aug 2019, 08:12 PM #16
3rd Aug 2019, 08:16 PM #17
Mill a slot in the end at the angle you want, then weld a cover plate on to make it a square hole.
If you don't have a mill put the bar in the toolpost at the right angle, and the milling cutter in the chuck.Using Tapatalk
3rd Aug 2019, 08:34 PM #18
Just to add I've mig welded HSS and had no problems.
Using Tapatalk
3rd Aug 2019, 08:46 PM #19Pink 10EE owner
- 6,218
Photos.....
20190803_193843.jpg 20190803_193858.jpgGold, the colour of choice for the discerning person.
3rd Aug 2019, 09:41 PM #20Most Valued Member
- Australia east coast
- 2,713
I've welded HSS to A36 steel with reasonable success. You need a really good pre-heat followed by a slow cool. I had my son holding the oxy torch to keep everything hot while I ran the beads.
You won't affect the temper.
Good chance you'll get cracking in the heat affected zone.
Brazing is - IMO - a better process but sometimes - shrug - you do what you do. I was making a 75mm multi-tooth 60 deg dovetail cutter and the HSS blanks were welded into the body. It then went on the T&C grinder and did the job. I still have it floating about the shop just in case I ever need it again.
PDW
3rd Aug 2019, 09:55 PM #21Most Valued Member
3rd Aug 2019, 09:59 PM #22Senior Member
- Nov 2012
- Mid North Coast NSW
- 423
Ok cool....I think I've got enough info from you guys to whip something up.
I received a couple of 5mm x 100mm HSS blanks I ordered from ebay on Friday so I've got a more than one go at it if I muck it up.
I've also got some 16mm square steel I can turn down to make it and end up with a better fit in the tool post.
These gear blanks are 20mm thick so I'll turn to around 25mm long and should keep some rigidity.
See how I go and I'll post a photo of the finished tool.
3rd Aug 2019, 11:12 PM #23
[QUOTE What should I do after welding it ?[/QUOTE]
Stand by and listen to the weld crack .
I have tried with stainless steel rod, Magna 303 rod, and a nickel rod . Like PDW said cracking in the HAZ and its straight away too,no waiting!
Brazing is the way to go.The fitter and turners I worked with( 1970s and 80s) always brazed HSS.
3rd Aug 2019, 11:57 PM #24Senior Member
- Jun 2005
- Townsville, Tropical Nth Qld.
- 226
I have TIG welded HSS to other various steel to make woodturning chisels using 316 filler rods and have not experienced any cracking.
Rgds,
Crocy.
4th Aug 2019, 01:30 AM #25Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
4th Aug 2019, 01:56 AM #26
That brings back memories
5-6 years ago we had a large market place that closed down (Moriset mega markets) where you could buy most things and it had 2 tool guys, one was an Indian guy and the other guy was Greek.
They both had similar gear over the years but the Indian guy had more lathe gear including small lathe chuck's etc, he used to sell these for around $10-$15 from memory and I bought a couple of different sizes among alot of if other things.Using Tapatalk
4th Aug 2019, 01:16 PM #27Most Valued Member
- Healesville
- 2,129
stainless rods
I just ducked down to the shed and glued some hss to some 1020.
In the past I used my pie warmer welder for this which is AC, now I have this little inverter DC welder, in this instance I used + earth but I think that these rods weld just as well either way.
I probably pick up the arc welder every 6 mths or so so I was off to a shaky start, actually while trying
to weld the welding rod reminded me of a dog scratching its ear with its hind leg
So the first was a piece of 1/4" hss welded to the end of the rod, 70amps was a bit low and combined with my
hand having an epileptic fit i got slag intrusion so I ran over it again.
Then I adjusted the amps to 100 and welded an old centre drill to the side of the rod, as you can see there is no
cracking and with a little practice perfect welds are the norm.
I have added some pics of another toolholder to cut keyways in the lathe, it is best to have another piece of toolsteel behind the one used to cut to reduce flex, other that this works fine.
It is best back the tool off the cut on the return.
cheers, shed
4th Aug 2019, 01:44 PM #28Diamond Member
- Jun 2010
- Canberra
- 1,322
I needed to cut an internal thread that was a much smaller diameter than my insert setup would fit into, so I glued a piece of drill bit on the end of a steel rod of unknown composition with TIG using steel filler, as I didn't know any better.
Worked fine.
8th Aug 2019, 08:07 PM #29Senior Member
- Nov 2012
- 423
Finally got back to it.
I silver soldered the HSS cutter and it looks to have turned out ok. Certainly soldered strong enough anyway.
Having a lot of trouble making it work though. I've managed to cut some of the first keyway but it's very slow and seems to be making a tapered slot because it pushes away from the job (springs) . Can't see why. I thought the grind I put on it would be good.
8th Aug 2019, 08:14 PM #30Pink 10EE owner
- 6,218
You only want a couple of degrees clearance after the cutting edge. it serves the purpose of limiting the depth of cut and stops the cutter digging in.. Much like the clearance on a parting tool.
oxy welding help
By bobsreturn2003 in forum WELDINGReplies: 4Last Post: 9th Jun 2011, 04:46 PM -
co2 for mig welding
By wodstok in forum METALWORK GENERALReplies: 2Last Post: 13th Jul 2010, 10:07 PM -
Welding gal
By Groggy in forum WELDINGReplies: 6Last Post: 10th May 2009, 11:00 PM -
Where do you do your welding?
By jmk89 in forum METALWORK GENERALReplies: 16Last Post: 13th Mar 2008, 01:42 AM -
new to welding.
By Bluegum in forum WELDINGReplies: 8Last Post: 24th Oct 2006, 09:22 PM
