Results 16 to 30 of 43
Thread: Need help with mill bit/s
2nd Aug 2019, 04:53 PM #16Member: Blue and white apron brigade
- 7,182
The other thing the OP hasn't specified his 16 mm tolerance, is 0.1, or 0.01 or 0.001 mm?
I haven't found a 16 mm anything that drills a 16.00 mm hole, and it usually ends up slightly oversize.
The only way I seem to be able to get good tolerances is with a boring bar or a reamer.
2nd Aug 2019, 11:17 PM #17Senior Member
- Feb 2013
- Bunya Mountains, Australia
- 69
- 182
Hi Peoples,
Thanx for all the helpful advice. I didn't realise just how complex it is to drill accurate holes.
I went into Equipment Sales today (I live in the bush) and looked at the Annular cutters. Really impressive .. but expensive. I presume you have to sharpen them, but how? The salesman didn't know. Surely you don't just throw them away.
So I decided on a 16mm Blacksmith Drill (tapered shank) and 5mm pilot hole. They're relatively cheap. Although at 200mm long I hope they fit high enough in the turret to clear the bed (hehee)
But I also think I'll buy a 16mm slot-drill just to compare the accuracy and the smoothness of the face cut.
And thanx for the pic of the angle plate. I may even have to buy some clamps. merde,
3rd Aug 2019, 01:24 AM #18
Hi Danny,
You may have to remove the draw bar to fit an MT3 taper drill in the spindle ! I have to on my mill, but there is a slot for a removal wedge, make sure that you have a wedge tool to remove the drill.Best Regards:
3rd Aug 2019, 10:20 AM #19Senior Member
- May 2019
- Picnic Point, Sydney
- 77
- 312
Is this machine so weak you have to drill a pilot hole? My way would be to get an old 15mm/15.5mm drill that's only about 3" long & drill both sides in one setting. No centre drill required with the short drill although the web thickness needs modifying. Do the 100 holes then ream them after that. No need to clamp.
3rd Aug 2019, 03:44 PM #20Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
3rd Aug 2019, 05:54 PM #21Senior Member
- Feb 2013
- 69
- 182
3rd Aug 2019, 05:56 PM #22Senior Member
- Feb 2013
- 69
- 182
3rd Aug 2019, 05:58 PM #23Senior Member
- Feb 2013
- 69
- 182
3rd Aug 2019, 06:08 PM #24Senior Member
- Feb 2013
- 69
- 182
These are the first 6 of the 400mm lengths (3 holes right through and 3 from the side for the set screws.)
There are 700mmm lengths with 6 holes as well
3rd Aug 2019, 07:20 PM #25Senior Member
- May 2019
- 77
- 312
I don't know what your point is with the material thickness. It wouldn't matter if it was 1.6mm thick or solid you only have to drill then ream. Save yourself a trip to Brisbane because H & F will tell you the same thing I did.
In my post I said to modify the web. I tried to photograph my 15.5mm drill but couldn't get the detail so the following picture is one of my 1 1/2" drills showing how I reduce the web size. It's a simple touch on the corner of your grinding wheel. Because of that web reduction I use that drill most times without a pilot so you certainly don't need one with a 15.5mm or 39/64" drill.
The reason I said a short drill is a new one has more tendency to wander if you don't use a centre drill but the shorter the drill the thicker the web ... hence the modification and no need for a centre drill. Do the drilling with the RHS clamped or in a vice but you don't need to contain for it reaming. Use a 2MT drill too, not a turned down shank job. DSCN0581.jpg
3rd Aug 2019, 07:55 PM #26Senior Member
- Feb 2013
- 69
- 182
4th Aug 2019, 01:09 AM #27Senior Member
- May 2019
- 77
- 312
Look up this site & go to web thinning. Drill Terminology and Cutting Characteristics | MITSUBISHI MATERIALS CORPORATION
In 50+ years as a toolmaker I've never heard of a reduced shank drill called a blacksmiths drill. You learn something every day. If you can get one in short series it will be OK but in a collet & not a chuck. Morse taper would be better & the shorter the better because you don't want to be mucking around with centre drills. A 15.5mm high speed steel from H & F will only cost you $22 but will be too long so I'd shorten it & sharpen it like the above. Looks like H & F don't sell machine reamers so find an engineers supply place. Don't use an adjustable reamer.
It's easy for me to tell you what to do but from what you say you aren't very experienced, so it might be worth your while to find an engineering workshop in Brisbane and ask if they could cut down and sharpen a drill for you with the reduced web. Maybe ask at H & F if the know such a place & could they ring ahead.
4th Aug 2019, 09:42 AM #28Senior Member
- Feb 2013
- 69
- 182
OK ... I understand that. By tapered-shank drill I meant Morse-Taper, I think.
I also have a full set of collets. Would it be just as good to buy a straight shaft 16mm drill (no taper) and cut it shorter and use it in the 16mm collet?
I'll look up how to thin the web.
Ta
4th Aug 2019, 10:55 AM #29Senior Member
- May 2019
- 77
- 312
Your choice whether you use a Morse taper or reduced shank drill but if you need an accurate 16.0 diameter hole you'll have to ream it after drilling a 15.5 or 39/64" hole. A badly sharpened 16mm drill could drill 0.5mm oversize and even a perfectly machine sharpened one will be a couple of thou over. If you go with a reduced shank (12.7mm) you can then use it in your hand drill when this job is finished.
4th Aug 2019, 11:18 AM #30Member: Blue and white apron brigade
- 7,182
This was my point a few pages back.
Before the OP does drilling he needs to measure the 16 mm rod in a number of places as not all 16 mm rod is 16.00 mm and neither is it all uniform, and then we need to know the tightness of fit required.
Reaming from 15.5 to 16 mm is hard work given you have so many to do.
In these cases I have used a 5/8" (15.875mm) drill which makes reaming the last 0.125mm a LOT easier.
BUT we have to know the bar size and fit required.
Then you must test the 5/8" drill as it may still make a hole that exceeds the spec you need for the rod.
Hercus o mill Vertical mill head lubrication
By china eyes in forum THE HERCUS AREAReplies: 0Last Post: 14th Oct 2018, 06:57 AM -
Selecting a small Mill / Mill/Drill
By Wombat200 in forum METALWORK GENERALReplies: 31Last Post: 15th Mar 2012, 10:58 PM -
Arboga EM825 mill vs Hercus model 0 mill?
By neksmerj in forum METALWORK GENERALReplies: 23Last Post: 14th May 2011, 03:16 PM -
Face Mill V End Mill
By eskimo in forum METALWORK GENERALReplies: 8Last Post: 31st Aug 2010, 03:19 AM -
