Results 1 to 4 of 4
Thread: under bench storage
1st Aug 2019, 11:15 AM #1Most Valued Member
- 4,258
under bench storage
as all are aware we need a lot more storage.
I had an old half height metal stationary cupboard sitting down the side of house storing crap. Binned with the crap and and pulled it down to the shed and thought mmm I could chop this down and fit it under the bench eh?
but what about all the other space along side?
I had one of those SS steel tool trolleys one gets from Bunnings..measured that up and it will fit if wheels are off..but still have vacant space..ahah another tool trolley will fit just nice
you can see the front of cupboard and how much I needed to chop so that it fitted under the bench...tool chests allready insitu
front was spot welded so I had to drill out to pull apart without damaging..rest of cupboard, sides and back was just bolted on.. sheet steel was around 1.4mm thick
Although the gap next to legs is some 30mm, there are two front to back channels iether end ontop of the legs and wider than the legs which reduces the space available by some 40mm which just allows the three items just squeeze in leaving about 5-7 mm clearance from one end only so tight fit really...
now for some silver/chrome paint
1st Aug 2019, 12:54 PM #2
Nice work, we all need more storage.
You could have cut the door so the handle was higher up to save bending.Using Tapatalk
1st Aug 2019, 01:08 PM #3Most Valued Member
- Charlestown NSW
- 1,673
Thats the trouble with these steel cupboards. All that wasted space at the bottom. If you were really pushed for room (and possibly desperate - I have actually considered this myself, but not yet desperate enough) A drawer could be made to go into that wasted space. Would probably be a good idea to fabricate a frame to go around the hole you would cut in the front bottom panel. You wouldn't even really need to buy drawer slides. A couple of inline skate wheels on each side of the drawer, just sitting on the floor would work.
peter
1st Aug 2019, 06:25 PM #4Most Valued Member
- 4,258
Bit Storage
By DSEL74 in forum METALWORK GENERALReplies: 30Last Post: 14th Jul 2015, 08:23 PM -
PM storage???
By JTTHECLOCKMAN in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 4Last Post: 29th Jun 2014, 09:59 PM -
Bench with Storage
By Blu_Rock in forum METALWORK GENERALReplies: 16Last Post: 5th Sep 2013, 10:27 PM -
Tap and Die storage
By bts in forum METALWORK GENERALReplies: 16Last Post: 17th Jul 2012, 07:42 PM -
bench top for a bench grinder
By wodstok in forum METALWORK GENERALReplies: 1Last Post: 24th Jan 2011, 03:04 PM
