Results 1 to 12 of 12
Thread: steel belt tool
30th Jul 2019, 08:30 PM #1New Member
- Jul 2019
- greece
- 3
steel belt tool
i want to make holes in a 1mm thick steel sheet (conveyor belt). Is there a hand held device which punches holes? Where can i get one?
30th Jul 2019, 08:44 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
I think the thing you are looking for is called a Whitney punch, how far into the sheet do you need to perforate?
30th Jul 2019, 09:15 PM #3New Member
- Jul 2019
- greece
- 3
30th Jul 2019, 09:15 PM #4
Hi and Welcome to the Forum,
Below is a picture of a Whitney punch available on Ebay.
The punch might limit how far you can place a hole from the edge of the sheet.
Feel free to introduce yourself in our Welcome wagon section. https://metalworkforums.com/f300
You will probably find there are more people willing to answer your question, if they feel you haven't just come here to get your answer for your problem and never be seen again.
30th Jul 2019, 09:19 PM #5Most Valued Member
- Jul 2016
- 35
- 1,522
I don't think there is any handheld tool which will do what you want.
30th Jul 2019, 09:46 PM #6New Member
- Jul 2019
- greece
- 3
30th Jul 2019, 10:07 PM #7Most Valued Member
- Jul 2016
- 35
- 1,522
Being that it's thin. If there is a lot of money in it you could probably make some kind of one sided magnetic punch using a big Spring powered punch held by an electromagnet. (you would need to punch with a lot of velocity)
Without a backup die it would probably be ragged.
Do you have 500 plates to do or one? How big is the hole?
30th Jul 2019, 10:25 PM #8
A brad point drill even though designed for wood working will drill a burr free hole in light sheet.
I have done this many times in thin sheet metal using HSS steel brad points. The sheet will need a sacrificial backing under it.
The bits are not too hard to re sharpen on a bench grinder with a suitable stone once you have got the bit profile.
30th Jul 2019, 10:53 PM #9Most Valued Member
- 4,887
Can you just buy the sheet?
31st Jul 2019, 10:36 AM #10Most Valued Member
- 4,255
How big are the holes you need to make
a chassis punch will do what you want, if holes are not too small or too large
https://www.asada.com.au/Products/Steel_Cutting/chassis-hole-punch.html
31st Jul 2019, 11:08 AM #11Most Valued Member
- Australia east coast
- 2,713
31st Jul 2019, 02:38 PM #12Senior Member
- May 2013
- Rockhampton, QLD
- 68
- 454
Welcome to the forum.
Multi tool belt grinder/linisher
By China in forum WANTED TO BUYReplies: 1Last Post: 2nd May 2019, 11:01 PM -
drive belt for Waldown C-1 tool post grinder
By Gippslander in forum WANTED TO BUYReplies: 1Last Post: 13th Jul 2016, 06:31 PM -
Anyone got a belt for a Cincinnatti Tool and Cutter grinder?
By Burner in forum METALWORK GENERALReplies: 4Last Post: 20th Jul 2014, 06:54 PM -
Supplier of high speed steel and tool steel bar and spring steel in melbourne?
By fudo133 in forum METALWORK GENERALReplies: 3Last Post: 25th Jun 2014, 12:44 PM -
Hercus Tool and Cutter Grinder - Spindle Drive Belt and Pulleys
By Anorak Bob in forum METALWORK GENERALReplies: 16Last Post: 6th May 2012, 03:32 PM
