Results 1 to 11 of 11
26th Jul 2019, 08:20 PM #1Diamond Member
- Aug 2006
- 1,106
What oil for enerpac hydraulic pumps?
Hi all,
Looking for an alternative to the Enerpac oil that is recommended to be used in there pumps. Currently looking into an hydraulic oil for a hand pump but wouldn't mind knowing a substitute for the air/hydralic and electric pumps as well for future use.
I am considering Castrol Hyspin but not quite sure about the required ISO rating.
https://www.ebay.com.au/itm/Castrol-...fc5d58bfb01149
26th Jul 2019, 08:26 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
Just regular old iso68 hydraulic fluid is fine, basically any detergent free oil will do the job.
26th Jul 2019, 09:26 PM #3Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
The place that rebuilds our pumps uses ATF.
26th Jul 2019, 09:28 PM #4Diamond Member
- Aug 2006
- 1,106
I have a drum of Shell Tellus ISO 68 so it would work out well if I could use that
I heard ATF is no good for the seals?
26th Jul 2019, 10:38 PM #5Diamond Member
- N.W.Tasmania
- 1,407
Make sure that you get any substitute right, a place I worked at for many years had to overhaul cylinders when someone substituted some other oil, after that they made sure the plenty of Enerpac oil on hand to avoid a repetition. That was a mine site with a good selection of oils to choose from, but the choice made was not good for seals. Not to say that there wouldn't be suitable oils of a generic type that would be every bit as good as the Enerpac stuff, but best check with someone who really knows, and not someone who thinks he may have an idea. An oil company should be able to advise you of suitability of their oils for the job.
26th Jul 2019, 10:48 PM #6Diamond Member
- N.W.Tasmania
- 1,407
It is just possible that the company doing the rebuilding uses seals which are good for ATF, whereas original equipment seals may indeed be unsuitable for ATF. If you know for sure that your pumps and cylinders all have OEM seals and O rings, you could check with Shell to see if Tellus 68 would be ok. A wrong substitution will cost you so it's worth getting the good oil so to speak.
26th Jul 2019, 11:36 PM #7Senior Member
- Perth, Western Australia
- 67
- 362
Any ISO 32 or 68 oil will do the job.
If the oil is to be used in a pump that runs a lot and the oil gets hot then 68 would be a better chose. For hand pumps 32 is more that adequate.
Never ever (and I mean EVER) use ATF in any hydraulic system unless recommended by the manufacture. It can lead to early seal failure.
In 10 years of servicing hydraulic equipment there were very few that would recommend ATF and enerpac was not one of them.
Tony
27th Jul 2019, 02:10 PM #8Diamond Member
- Aug 2006
- 1,106
If I use the 68 in a hand pump will it cause any damage?
It being a heavier oil will there be a big difference in the speed that the cylinder advances and retracts?
27th Jul 2019, 04:26 PM #9Senior Member
- 67
- 362
27th Jul 2019, 04:36 PM #10Senior Member
- 67
- 362
Ooops doubled up
27th Jul 2019, 04:47 PM #11Diamond Member
- Aug 2006
- 1,106
FREE: Compressor pumps and motors
By lamestllama in forum METALWORK - Machinery, Equipment, MARKETReplies: 16Last Post: 7th Apr 2019, 12:33 AM -
Hydraulic ram
By GSRocket in forum METALWORK GENERALReplies: 8Last Post: 6th Oct 2012, 10:19 AM -
Enerpac oil
By Michael G in forum METALWORK GENERALReplies: 11Last Post: 25th Sep 2012, 11:00 AM -
hares & forbes coolant pumps?
By Com_VC in forum METALWORK GENERALReplies: 23Last Post: 2nd Apr 2011, 06:54 PM -
Coolant pumps in reverse
By Stustoys in forum METALWORK GENERALReplies: 31Last Post: 7th Aug 2010, 10:50 AM
