Results 1 to 11 of 11
20th Jul 2019, 12:05 PM #1Most Valued Member
- Jul 2016
- 35
- 1,522
Help, planer or long bed mill owners
If anyone here has a planer or long bed mill I need to put a 6' long keyway in a replacement feed shaft on my DSG. It has too many bends as well as a decent twist in it. Being in or near Melbourne would be a big bonus but I can courier if needed.
Happy to pay, trade work or tooling for it.
Keyway is 1/4" X 50"
20th Jul 2019, 12:41 PM #2Pink 10EE owner
- 6,218
You should be able to do it on your mill. Just cut and move the part, cut again.
I cut a new feedscrew for the 10EE on just a bridgeport clone.
Something that long and a cut on one side, there is the risk of it bowing as stresses are relieved.Gold, the colour of choice for the discerning person.
20th Jul 2019, 01:18 PM #3Most Valued Member
- Healesville
- 2,129
You can use my mill if like Ralph, it has about 750 mm travel so you would only have to move it once.
Would use the DH and tailstock to hold it and would probably need a suport betwen them
I think 41 mm dia goes through the DH bore.
What dia is it?
cheers, shed
20th Jul 2019, 03:45 PM #4Most Valued Member
- Australia east coast
- 2,713
This. It won't matter if it moves a touch as long as the keyed part slides freely on the shaft. Set up a guide fence, raise the cutter a couple of thousandths then slide the shaft to the new starting position. The cutter and fence will keep alignment quite closely.
If you get stuck locally I'll be passing through in a bit over a week and can do it on my planer or mill when I get home. Might just get 50" on the planer.
PDW
20th Jul 2019, 08:37 PM #5
I agree with what everyone said and do it in stages, a fence setup is a good idea as PDW stated, it would be hard to get it wrong doing it that way.
Using Tapatalk
20th Jul 2019, 08:41 PM #6Most Valued Member
- Jul 2016
- 35
- 1,522
Thanjs fellas. Guess I'm just doing this 499mm at a time.
20th Jul 2019, 09:34 PM #7
I have a touch more at 600mm, I have always wanted a mill with 1000mm plus X travel, but it's only the occasional job that it would be handy for.
Using Tapatalk
21st Jul 2019, 09:11 AM #8Philomath in training
I bid 650mm X travel!
I'd also suggest that if you have a horizontal axis, rather than use an end mill, use a slotting saw type cutter. If you use a T slot as a locator/ support it will also help line things up when you move the work.
22nd Jul 2019, 05:30 PM #9Most Valued Member
- 2,713
22nd Jul 2019, 09:56 PM #10
23rd Jul 2019, 12:21 AM #11Golden Member
- Jul 2011
- 837
I keep reading that the lathe is the only machine that can duplicate itself. So I suggest you make it on the lathe.
Resources for round column mill owners
By steamingbill in forum METALWORK GENERALReplies: 1Last Post: 11th Oct 2017, 07:30 PM -
Purpose built mill or converted metal planer?
By Burner in forum METALWORK GENERALReplies: 4Last Post: 24th Aug 2016, 10:10 PM -
Aussie AL-960 owners or previous owners input please?
By befuddled in forum METALWORK GENERALReplies: 4Last Post: 6th Jun 2015, 10:14 PM -
Newcastle: Large mill / planer / grinder needed for job
By pippin88 in forum METALWORK GENERALReplies: 17Last Post: 7th Feb 2014, 08:42 AM -
question for the 45 size mill owners
By texx in forum METALWORK GENERALReplies: 15Last Post: 10th Nov 2013, 09:43 AM
