Results 1 to 3 of 3
Thread: Threading bit.
20th Jul 2019, 06:57 AM #1
Threading bit.
Some of you might recall that I found a tin of various bits and pieces recently. (See thread "Scrap Yard Goodies") One of the items in the tin was a threading tool.
This is the tool circled in red.
It is a 55 degree threading tool bit. As it happens I needed one today and this was all that I had. It wasn't until I had used it that I discovered that it was actually a carbide tip. It was brazed onto a piece of 5/16" mild steel bar and obviously ground using a tool and cutter grinder. At 50 rpm it did a very reasonable job of single pointing a 7/16" X 18 tpi thread (7/16" BSF).
Bearing in mind how old the other items in the tin could have been, I find it remarkable that someone hand made this thread cutting tip. The 60 degree counter sink bit, just to the left has also been hand made.Best Regards:
20th Jul 2019, 07:41 AM #2
Its not all that hard to do, if you have the gear and the patience. It was a common occurrence when I was an apprentice.
Hafco AL320G Lathe
Toolex RF31 Mill/Drill
Saber Bandsaw
20th Jul 2019, 09:30 PM #3Member
- Nov 2009
- australia
Nothing new about that at all, it's still done today --------
Need some help threading
By Ghrober in forum THE HERCUS AREAReplies: 14Last Post: 15th Oct 2016, 01:03 AM -
Threading close pipe nipples with a hand threader and block type threading dies.
By aametalmaster in forum METALWORK GENERALReplies: 5Last Post: 11th Sep 2015, 07:22 AM -
Threading Stainless
By DSEL74 in forum METALWORK GENERALReplies: 9Last Post: 21st Dec 2014, 09:43 PM -
need help with threading
By justron in forum METALWORK GENERALReplies: 1Last Post: 2nd Sep 2014, 11:04 PM -
Threading again
By morrisman in forum METALWORK GENERALReplies: 18Last Post: 10th Dec 2011, 03:16 PM
