Page 1 of 2 12 LastLast
Results 1 to 15 of 22
    Nov 2007
    melbourne australia
    3,228
    Default Emery on the lathe
    I watched this short YouTube video and was surprised by the number of commenters who've had it happen to them. I always hold one end of the emery tape in each hand. I thought everyone did. Apparently not.
    https://www.youtube.com/watch?v=p5iKM-vC6LM
    Apr 2012
    Healesville
    2,129
    Ditto.... and I would use a much longer length of emery than what Joe was demonstrating with and pull it back
    and forth so it doesn't rub in the one spot.
    cheers, shed
    Dec 2013
    56
    1,418
    cheers, shed
    Yeah I used Emery 5-6 times today and use it fairly often depending on the job/finish.
    I usually rip a strips of different grades around 500-600mm long and they live in the drawer under the lathe.
    I hold it close to the the ends and use the whole strip, unless I'm sanding something intricate up to a corner etc for cosmetic looks, then I fold it in half and sand from one side (I'll post this project soon)
    I've read lots of people won't use Emery on there lathe, same as filing etc. I've got way covers which helps keeps grit out, but even on a lathe without them I'd use it, just keep up good house keeping on the lathe and it won't do any harm.
    Using Tapatalk
    6,475
    That is only one way to use abrasive paper on a lathe ! I use a length of hard wood with an abrasive paper glued to it, very much like using a file. The other method is still a stick but a longer length folded over the end !
    I'm not keen on this because its easy to push the abrasive paper off the stick and get it wrapped around the work piece.
    One other trick I've used is to apply abrasive paste to a softwood stick and use it to polish surfaces for bearings and the like.
    Mar 2014
    South of Adelaide
    1,227
    yeah always emery with 2 hands. We use emery on the lathes at work every day, we just wipe the bed down with rags when we are finished, after 10 years all our lathes are fine.
    Sep 2006
    Mallacoota,VIC,Australia
    53
    1,010
    Yeah same as Snapatap, I've always used emery in two hands. This also comes down to why you have to be careful if your using gloves around machinery. I don't use gloves around rotating machinery, but there is certain times when they are necessary.
    All The Best steran50 Stewart
    Dec 2013
    56
    1,418
    Quote Originally Posted by steran50 View Post
    I cut my finger the other month moving swarf away so it didn't get caught up on the chuck. Ten minutes latter I did another finger, then went and got a pair of pliers lol.
    After all these years you would think I'd be aware, but this swarf was long and razor sharp.
    My neighbour seen my paper towel and eleco tape bandaids while it stoped bleeding on the lathe/job and asked what happened.
    After I told him he suggested gloves, him being a farm sort of guy and not being a machinist thought you wore gloves using machinery. Would rather a cut than to loose a finger or worse.
    Gloves are fine for cleaning up, but I still don't use them, I do see some people on forums wearing those thin medical type of gloves.
    Using Tapatalk
    Jun 2016
    Sydney
    283
    Default Long winded
    The guy in the video does crap on at some length, doesn't he?
    OK, he demonstrated a few things you should not do, but he could have done that in less than half the time.
    Roger
    7,189
    Quote Originally Posted by rcaffin View Post
    99% of web vids are like that - lucky there's a fast FWD slider.
    Jun 2016
    Sydney
    283
    Default Audio
    I just turn the audio off - or remove the headphones.
    Then I run along the slider at the bottom and look at the pics there.
    Roger
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    I cut my finger the other month moving swarf away so it didn't get caught up on the chuck. Ten minutes latter I did another finger, then went and got a pair of pliers...
    One of the first things I did with this lathe was extend the chuck key handles for the cam lock fitting on the lathe (the key originally could not be turned before banging into the chuck) and smaller chucks I have.
    As by-product, I've discovered that they double as an excellent 'rake' for pulling swarf away.
    I won't touch swarf unless the lathe is stopped or it is dead on the floor. My 3 jaw in particular has a nasty habit of catching a long piece and then pulling up the stuff in the tray. I don't want to be pulling a piece of swarf away at the moment the lathe decides on a tug of war.
    Dec 2013
    56
    1,418
    I also made up a extended D1-4 handle, I'll have to grab a picture, though I think I posted it years ago.
    I won't go near swarf that I think is going to get caught up, just the loose stuff that's been spat out.
    Really need to make a swarf rake, should put it higher on my list, lol
    Using Tapatalk
    Nov 2010
    Gippsland Victoria
    733
    Default Clever gadget to hold emery cloth
    https://www.sponmech.co.uk/sanding-b...for-lathes-p31
    Further down in the comments beneath the video somebody recommends this thing. You could efficiently use the entire length of emery.
    Wouldnt be too hard to make a very much simpler version yourself. Simplest might be a handheld crescent of plywood (ie similar shape to an archery bow)
    Could either be hand held or toolpost mounted.
    Funny thing, when I first started I tried for aaaages to get nice smooth finishes straight off the tool, got there in the end (shear tool) but didnt realise that people commonly used emery.
    Bill
    Nov 2007
    melbourne australia
    3,228
    Gotta love the alarmist language in the marketing blurb for the tool. Although there’s a link to a document on the use of emery.
    https://www.sponmech.co.uk/files/dow...%20rev%201.pdf
    It shows a way of holding emery cloth in a standard QCTP holder. I think it would be very wasteful of emery though as only a small section of the emery contacts the work.
    And in the photo of the bloke holding emery tape in his hands he has it wrapped around his fingers. Of course you’re going to lose a bloody finger if you do that and it catches. Common sense (yeah, I know) says you pinch it between index finger and thumb. I can’t see the danger if you do it that way.
  15. #15
    6,475
    Hi Chris, Guys,
    I agree with you ! Whilst I have used abrasive paper in very much the same way, I much prefer the sanding stick method. For sanding and lapping bores, I also use a wooden dowel with a strip of abrasive held in a slit in the end. Not much to get caught that way.
    I've also used those small Dremal flap discs for sanding small bores. Very handy using the drill press as a vertical grinder.
  1. File & Emery
    Last Post: 24th Oct 2015, 09:35 PM
  2. Replies: 2
    Last Post: 15th Jul 2013, 01:24 AM
  3. SOLD: Lathe for Lathe Drill Mill (Near Liverpool NSW)
    By Auskart in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 29th Jun 2010, 07:02 PM
  4. Buying a lathe (Old massive Lathe, or New small C6 Lathe)
    By Ch4iS in forum METALWORK GENERAL
    Last Post: 25th Mar 2009, 12:19 PM
