Results 1 to 4 of 4
Thread: Flail blades
10th Jul 2019, 06:02 PM #1Senior Member
- Nov 2010
- Frankston south
- 102
Flail blades
Hi all, I'm hoping someone might be able to advise me on what Steel grade Flail blades are made from? Typically a garden variety Masport or Caravaggi
10th Jul 2019, 06:44 PM #2Most Valued Member
- Healesville
- 2,129
I think that it would be a bit risky making your own blades, if one somehow broke and got out of there and imbedded itself into someones face or some other piece of their anatomy you would be in the sh## big time.
I have worked in a few and owned a power equipment business and in that time other mechanics and myself
when fitting new blades to anything ALWAYS used new blades and nut and bolt set, this way if someone catches
a blade and there is an inquiry then you should be ok, providing the blade did not come off because you didn't do a nut up.
I have heard quite a few tales about blades coming off and seen quite a few that have broken in half and through the blade bolt holes.
In short my advice is don't!
Buy the OEM blades and bolt set.
cheers, shed
10th Jul 2019, 09:20 PM #3Most Valued Member
I'm pretty sure they are spring steel. I recently replaced all the flails on my mulcher. They are also known as hammers if that helps your Google searching.
Mine were this type (US website):
https://www.chalmersindustries.com/p...-p/1900102.htmChris
10th Jul 2019, 09:50 PM #4Most Valued Member
- Australia east coast
- 2,713
Mulcher Flail Spacers
By jack620 in forum METALWORK GENERALReplies: 8Last Post: 8th Oct 2018, 03:03 PM -
Vic cold cut saw blades.
By azzrock in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 13th Apr 2017, 08:13 PM -
Parting off blades
By leroy in forum METALWORK GENERALReplies: 11Last Post: 25th Jan 2013, 05:02 PM -
TCT blades...
By RHiSC in forum METALWORK GENERALReplies: 1Last Post: 28th Jul 2009, 10:49 PM
