Results 1 to 1 of 1
Thread: The Versatile "Magic Arm" Clamp
7th Jul 2019, 10:02 AM #1.
- 6,459
Not the real Manfrotto clamp but a far less expensive and probably more useful Chinese version - https://www.ebay.com/itm/Magic-Arm-S...oAAOSwuxFY4GSz
There are a few variations of these little clamps, some come with additional swivelling jaws, different handles and different thread mounts. They are camera accessories and are typically threaded 1/4", 3/8" BSW or a combination of both.
I've had a couple for quite some time and found one of them handy for attaching a simple centring microscope to my Noga base. The first photo below shows a somewhat cumbersome setup using a real Manfrotto Magic Arm and its clamps to support the scope. The second shows the streamlined Israeli/Chinese combination.
Not everyone owns or wants to own a centring microscope but I imagine I'm not the only one who benefits from some form of optical enhancement. Most often I wear a Donegal Optivisor but there are times when it is unsafe to be too close to the action so when I saw Swiss toolmaker, William Brem's nifty loupe holder on his Swiss tool Yahoo group site, it all clicked. William 3D prints his holders and offers them for sale with a good quality ASCO loupe for around 40 Euros plus shipping. Not unreasonable given the price of the loupe - https://www.ebay.com.au/i/1534069369...UaAgTUEALw_wcB
William's holder -
I have three loupes, two Bausch and Lombs and a no name (could be Peak ) Japanese. The later I use in the shed. Possessing neither a 3D printer nor the ability to use one along with an unwillingness to part with over a hundred dollars I sought an alternative. My plan had been to use my shed loupe in conjunction with a cheap Chinese indicator arm on an equally cheap magnetic base, shown here performing alignment duties -
The magnet isn't overly poweful and I was concerned that with the Chinese clamp attached top heaviness would become an issue. I looked for alternatives such as cheap and light fishing rod holders, cue holders and tent pole clips but nothing I found would suit the loupe's body diameter of 28.5mm.
So then I thought about the Starrett "Flex-O-Post" holder I've had for years but never used because I own a Noga. All it needed was an adaptor from 3/8" round to 1/4" BSW. With the clamp attached it is a versatile combination. Apart from loupe support being able to position the Sunnex lamp on the left side of the mill's spindle will be a huge advantage. Will certainly beat using a torch.
IMG_20190705_162254956.jpg IMG_20190705_162437739.jpg IMG_20190705_160722015.jpg IMG_20190705_160548548.jpg IMG_20190705_160857387.jpg IMG_20190705_161007190.jpg
Inexpensive versatility.
BT
Ignyte Precision Granite Surface Plate 24" x 18" x 4"
By kwijibo99 in forum METALWORK - Machinery, Equipment, MARKETReplies: 10Last Post: 5th Jul 2016, 10:41 PM -
Versatile Tool and Cutter Grinder "made in Melbourne"
By Garry Edwards in forum METALWORK GENERALReplies: 7Last Post: 22nd Feb 2012, 09:50 PM -
Opposing toothed "Clutch-Plate" Nuts? (a bit like "Castle" Nuts...)
By Batpig in forum METALWORK GENERALReplies: 6Last Post: 5th May 2009, 08:18 PM -
Difference "Galvanised" and "Primed" Steel
By Fr_303 in forum METALWORK GENERALReplies: 4Last Post: 22nd Jan 2008, 05:59 PM
