Page 5 of 5 FirstFirst 12345
Results 61 to 72 of 72
  1. #61
    Dec 2011
    Rosebery/Eastlakes
    100
    Hi BaronJ,
    I was relieved to say the least as destroying the shaft was not on my radar. I even contemplated drilling and tapping holes in the bushing and using a slide hammer to try removing it to leave the shaft insitu.. But the heat was definitely worth a try! Yes I have kept them together.
  2. #62
    Dec 2011
    Rosebery/Eastlakes
    100
    Hi everyone..
    So it has been a while since I put any time into this project and the headstock is still in pieces.
    One thing that I have confirmed is that the intermediate gear shaft is bent. My crude assessment is that the shaft has at least 0.015" runout. The net effect is that the shaft has worn out the bronze bearing at the change gear end.
    My question is can the shaft be flame straightened or would it be easier to have it re-manufactured? The second part is does anyone know where in Sydney I can get this done? I will need to get new bronze bearings made as well.
    Flo
  3. #63
    Oct 2011
    Norwood-ish, Adelaide
    55
    5,488
    Before applying heat, I would try straightening it in a hydraulic press. 15 thou is not an enormous amount and should come out.
  4. #64
    Charlestown NSW
    61
    1,291
    What Michael said with the added bit if you haven't done this sort of job with a press before, then take it to someone who has experience straightening shafts etc. With no or little experience, it would be very easy to turn your .015" into a lot bigger number.
    Paying someone to straighten it would still be a lot cheaper than paying someone to make a new one.
    peter
  5. #65
    Dec 2011
    Rosebery/Eastlakes
    100
    Hi Michael,
    Unfortunately I don't have a hydraulic press nor do I have a way of accurately measuring the total runout. The 15 thou was a crude estimation using a couple of vee blocks and an indicator. It's entirely possible that it is more.. The bearing is heavily worn..
    Flo
  6. #66
    North Yorkshire UK
    3,207
    When I did the refurbishment of my bandsaw, the pivot shaft was bent around 40 thou or so. It only took a couple of minutes with a hydraulic press to straighten it. Its still bent, but its now only around 1/2 to 1 thou at the end.
    https://metalworkforums.com/f65/t203...Bandsaw+BaronJ
    Post 14.
  7. #67
    Dec 2011
    Rosebery/Eastlakes
    100
    Quote Originally Posted by bollie7 View Post
    peter
    Hi Peter,
    Thanks for your reply. I was not planning on attempting it myself - I was wanting to get someone to do it, hence my query about suitable places in Sydney. Maybe I wasn't as clear as I should have been.. my apologies.
    Flo
  8. #68
    Charlestown NSW
    61
    1,291
    Quote Originally Posted by Flo View Post
    Hi Peter,
    Flo
    All good. I have a personal experience of trying to straighten a shaft myself once. Got there in the end but but made it worse before I made it better.
    Does the shaft have a centre hole in each end? If yes then if you can get access to another lathe somewhere, mount it between centres you will be able to get a real good idea of the run out.
    Actually you could possibly get a good idea on you own lathe even though the headstock is in bits. If you still have the saddle/ tool post on it and the tailstock. If you have a bit of round bar with point on it that you can hold with the tool post and a centre in the tailstock. you could hold the shaft between them and using a dial gauge you could get a run out figure. You could even use a drill bit clamped in the toolpost as long as you only turn the shaft backwards in relation to the cutting edge of the drill.
    As long as the two centres are close to the same height it would work. You would have to reset the position of the dial gauge for each location you wanted to measure but you should be able to get an accurate reading.
    Desperate men etc.
    peter
  9. #69
    Dec 2011
    Rosebery/Eastlakes
    100
    Post 14.
    Hi BaronJ,
    Maybe I need to get me a hydraulic press..
    Flo
  10. #70
    Dec 2011
    Rosebery/Eastlakes
    100
    Desperate men etc.
    peter
    Hi Peter,
    The saddle is still fitted but the tailstock is in pieces.. I might have to see what I can do .. I like your suggestion though.
    Flo
  11. #71
    North Yorkshire UK
    3,207
    Hi Flo, Guys,
    I held the bar in a collet on the lathe at one end and used a dial gauge to measure it at different points along its length. The bend on the bar was about 3" up from one end.
    After straightening putting the bar in the collet from either end showed that the bar was virtually dead straight.
  12. #72
    Charlestown NSW
    61
    1,291
    25 or so years ago I was pressing a new steel timing gear onto Holden red 6 crank. I was using a Hyd press at work during lunch so was rushing a bit. Anyway the spacer I was using to get past the end of the crank onto the gear moved or something and I ended up putting a .025" bend in the crank. Wasn't my finest hour.
    Anyway I straightened it on my old Purcell lathe by holding it between centres. Put a lump of 12mm thick X 100mm wide plate across the ways, ( I had something between the ways and the plate but I cant remember what it was. The old lathe had flat ways which was an advantage in this situation) Then I used an engineers screw jack between the plate and the appropriate journal and straitened it that way. I had to push it about .040" the opposite way to allow for spring but after an hour or so go it to about .002". It was easy to spring it more than that just by pushing on it with my hand so I figured being a 7 main crank it would be fine. Which it was.
    That engine(although no longer mine) has about 50,000 klm on it now since it was rebuilt and still running fine apparently.
    peter
  1. New Visby lathe.
    By stix012 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 30th Mar 2017, 01:42 PM
  2. New Visby cleanup
    By morrisman in forum ANTIQUE AND VINTAGE MACHINERY
    Last Post: 10th Nov 2016, 10:22 PM
  3. New Visby on Gumtree
    By j.ashburn in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 21st Jun 2014, 03:19 PM
  4. Visby lathe
    Last Post: 9th Oct 2013, 06:41 PM
  5. New Visby
    Last Post: 30th Nov 2011, 01:56 PM
