Results 1 to 15 of 25
Thread: Kerosene and Knurling
4th Jul 2019, 01:41 PM #1.
- 6,459
I was making some screws the other day for some table adjusters and needed to knurl the 1214 I was using.
Previously I have used thin spindle oil, heavier engine oil and ATF as lubricant during the knurling process, resulting in a chip filled slurry. The results have been acceptable IMO but it is difficult to see clearly the depth and finish of the knurl during the knurling.
I had some kero at hand so I gave it a go. No slurry, the chips washed away resulting in an easily observable knurl. I used a stiff bristled Super Cheap parts cleaning brush to apply the kerosene which resulted in kerosene being flicked everywhere. Next time I will use a squeeze bottle to application and a cake tray for collection.
IMG_20190625_091311034.jpg IMG_20190625_110426498.jpg IMG_20190625_111510018.jpg IMG_20190625_152653_01.jpg
BT
4th Jul 2019, 02:14 PM #2Member
- Nov 2009
- australia
1214 steel is rather soft and very easily knurled WITHOUT and lubricant at all.
https://www.ebay.co.uk/sch/i.html?_f...03720&_sacat=0
4th Jul 2019, 02:24 PM #3.
- 6,459
4th Jul 2019, 02:31 PM #4Senior Member
- Oct 2010
- NSW
- 181
Good one Bob. Yeah I'll be using a squeeze bottle next time too. Last time I used a brush and I poked in the wrong place with exciting results.
4th Jul 2019, 02:36 PM #5.
- 6,459
Thanks Picko,
My parts brush is short a number of bristles. Grated nylon isn't a knurling enhancement!!
4th Jul 2019, 06:39 PM #6
Hi Bob, Guys,
Very nice knurl pattern on those parts.
The behaviour of different cutting fluids and pastes is surprising ! I don't think that there is just one that you can say is the right one for all materials. I also use diesel / kero in a squeeze bottle, along with WD40, Trefolex and some others.Best Regards:
4th Jul 2019, 07:13 PM #7Most Valued Member
Two posts in one day Bob. You're spoiling us! Glad the kero came through for you. Unfortunately the smell of it (and diesel) makes me want to puke. Maybe all those years working in a petrol station as a kid.
4th Jul 2019, 07:55 PM #8Member: Blue and white apron brigade
'I'm the same with Kero and was using the other day to turn some acrylic but I got away with it because of the ventilation I have in my shed.
For me kero aroma reminds me of a holiday as a kid where I got sick as and the place we were staying in had a kero fridge. Even since then kero smells make me slightly nauseated.]
4th Jul 2019, 08:02 PM #9
Nice job Bob, and nice to see your clear pictured posts.
I remember years ago where you questioned me about knurling the 50 odd tool post adjusters I was making using coolant instead of oil etc.
I was using a makeshift coolant setup at the time from my mill to wash away the chips and a magnet picking them up in the bottom.
The difference is night and day even in mild steel as you have seen The knurls came out nice clean and crisp like yours have.
Here is the post, then I just see it went off about the knurls tool.
Making Dickson style quick change tool post holders (picture heavy)
Have you thought about a simple coolant setup with a tray that sits on your lathe and a $6 pond pump? It would save the Kero smell and be recycled.
Dave JUsing Tapatalk
4th Jul 2019, 08:45 PM #10.
- 6,459
Thanks Dave,
I remember your tool holder thread well. A colossal effort!
I've shied away from water based coolant because the one time I did use it I ended up with some corrosion on my, then pristine, cross slide. While I'm not a big fan of kero and its accompanying smell I can put up with it.
I've always been keen to try cutting oil but have balked at its cost. For the amount of knurling I do kero or similar in a squeeze bottle will probably suffice.
I do need to take a close look at Bob L's coolant setup he has on his Hercus lathe and another closer look of the mist system he has devised for his little Hercus mill.
Bob.
4th Jul 2019, 09:08 PM #11
5th Jul 2019, 08:49 AM #12Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
Hi BT
A nice job of knurling and your usual great photo's. As you know I have been using a mix of used ATF and kerosene in a mist cooling system on my lathe and mill for some time now. When knurling I have always used a flood system of just the used ATF oil, a little while ago I cut a knurl and used the mist coolant system and adjusted the flow rate up a bit and found this worked really well as the increased flow and extra air pressure blew away any loose chips and also enabled better vision of the knurl.As I only had one short knurl to cut I did not take a picture but I will next time.
Bob
5th Jul 2019, 10:54 AM #13Most Valued Member
- Australia east coast
- 2,713
5th Jul 2019, 11:33 AM #14
5th Jul 2019, 11:55 AM #15
Talking about Kero reminded me about prices and quantity, has anyone else noticed over the past 3 years the containers have gone down to 3ltr but the price went up again.
I used to buy this stuff for mum for our heater at the local servo for 20 cent's a little in a glass 4l orange juice glass bottle.Using Tapatalk
Kerosene Pressure Lantern
By DSEL74 in forum ANTIQUE AND VINTAGE MACHINERYReplies: 7Last Post: 11th Jan 2017, 09:47 PM -
Knurling
By jhovel in forum METALWORK GENERALReplies: 5Last Post: 28th May 2016, 01:44 PM -
Blast from the Past - Darlton Kerosene Blowlamp
By franco in forum METALWORK GENERALReplies: 5Last Post: 27th Jul 2014, 03:46 PM -
Knurling
By YarrD in forum METALWORK GENERALReplies: 11Last Post: 27th Jan 2011, 08:25 PM -
Knurling
By footz in forum THE HERCUS AREAReplies: 4Last Post: 20th Sep 2008, 10:07 PM
