Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    Nov 2007
    melbourne australia
    3,228
    Turps is cheaper than kero at Bunnings. Has anyone tried it as a lube?
  2. #17
    Dec 2013
    56
    1,418
    Never even thought to try it, but it has it's own odour.
    Using Tapatalk
  3. #18
    7,189
    You can get odourless kero in Bunnings. Friends of mine use it in their Primus type stove on their boat. It's a bit more expensive than the blue stuff but burns cleaner, not that it matters for your purpose.
    PDW
    Just a heads up that odourless kero has the same OHS issues including exposure limits etc as ordinary kero. The low odour might in some situations even make it more dangerous than normal kero as the odour of ordinary kero warns folks that it might be time to do something about vapour build up. If someone experiences ill effects due to the basic hydrocarbon components then they might wonder why if the can't smell much and they are feeling crook.
    Despite this I will be using it as soon as I use up the remainder of what I collected from mum and Dad's shed when mum moved into my sisters place. There were 4 bottles of regular Kero not to mention other flammables and various (many poisonous) garden chemicals. I took a van load to the waste transfer station and the attendant thought I was clearing out a nursery.
  4. #19
    6,475
    I took about 20 Ltr of old engine oil to the council dump the other day ! Talk about "Jobs Worth"...
    I had to tip it into a large plastic container, which had a lidded hole on top with a grill across it. The container was as tall as I am, I had to stand on the bunding to reach the fill hole.
    Now the waste oil that I had was in a 25 Ltr container. I simply couldn't lift the container that high, so I asked one of the attendants if he would give me a hand. "No" was the curt reply, "you have to put it into smaller containers" and off he walked, down between two skips and then lit up a fag !!!
    I was able to rescue a 5 Ltr plastic bucket from some chap that was disposing of it, and used that to get my old oil into the tank. I disposed of both containers in one of the skips. I don't know if it was the right skip or not, at this point I didn't care.
    I do know that an incineration plant was built not too far away, one of the neighbours suggested they might have taken the old oil.
  5. #20
    Nov 2008
    Perth WA
    6,459
    Default 4140, WD-40 and a pair of fish tins.
    This morning I made a replacement M4 thumbscrew for my daughter's piercing saw. The 4140 I used knurled nicely with, tooth brush applied only to the top wheel, WD-40. Slightly coarser pitch than the original but close enough to keep everyone happy.
    Certainly nowhere near the mess created with kero and a parts cleaning brush!
    BT
  6. #21
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    One of the things I find contributes to a successful knurl is not winding in too much. Empirically, I find that winding the knurls in around half the pitch seems to give a sharp knurl. Less and it is not fully formed, more and it risks distorting the knurl (for scissor type knurl, total movement would be double that).
  7. #22
    Jul 2011
    Adelaide
    837
    Anorak Bob,
    You seem to be using the knurling tool on a rear tool post. Is that so you get a better view or is there some other reason?
    Eric
  8. #23
    Nov 2008
    Perth WA
    6,459
    Quote Originally Posted by lamestllama View Post
    Anorak Bob,
    Eric
    Just visibility Eric.
    Hercus%20ARL%20with%20Knurling%20Tool%20%20%20%20Mounted%20On%20Rear%20Toolpost%20001.jpg
  9. #24
    Sep 2006
    South Coast of New South Wales Australia
    296
    I can't stand the smell of kero either and use WD40 for knurling, much better than the slurry you get when using oil.
    Cheers Jim
    My Youtube Channel -
    Blue Heeler's Model & Toy Steam Engine Room
  10. #25
    Jul 2006
    Athelstone, SA 5076
    4,258
    i havent done that much knurling, but I recall using anything that was in reach...spray can refrigeration oil, squirt bottle of refrigeration oil, ordinary CRC, CRC long life, squirt bottle of automotive oil use ..ditto ATF oil and kero, ...anything I missed?
    sounds like I need to try neat kero...
  1. Kerosene Pressure Lantern
    By DSEL74 in forum ANTIQUE AND VINTAGE MACHINERY
    Last Post: 11th Jan 2017, 09:47 PM
  2. Knurling
    Last Post: 28th May 2016, 01:44 PM
  3. Blast from the Past - Darlton Kerosene Blowlamp
    By franco in forum METALWORK GENERAL
    Last Post: 27th Jul 2014, 03:46 PM
  4. Knurling
    By YarrD in forum METALWORK GENERAL
    Last Post: 27th Jan 2011, 08:25 PM
  5. Knurling
    By footz in forum THE HERCUS AREA
    Last Post: 20th Sep 2008, 10:07 PM
