Results 1 to 8 of 8
    6,443
    Thumbs up Scrap yard goodies !
    I’ve been nosing around in the scrap yard again this morning, looking for a piece of aluminium bar to make the calibrated knob for the TCG. I also found an old tin with some bits and pieces in it. The nice man at the scrap yard had also found a set of number stamps which he had kindly put on one side. I also picked up a very old thermostat in a Bakelite case.
    This is the tin that I found with all the items in the family picture, exept for the number stamps and the 5" micrometer standard, manufactured by J. Slocum of Sheffield, UK.
    These are the number stamps. They look to be about 5 mm in size. Very faintly stamped into the wood is the name Hook?? and what looks like a date 1986 or it could be 1988. They are very rusty, I'm going to try and de-rust them.
    These were in the tin. A collection of mainly taps, some are broken. That "T" slot cutter in the middle is a MT3 taper shank. A couple still have the protective coating on them. That little tool bit on the right is a 55 degree threading bit.
    This is the thermostat that I picked up simply out of curiosity. I took the case off just to have a look inside. That knob on the right compresses that thumping great spring. I wound it down to as low as it would go and blew hot air on it, those contacts close with a loud thud. I wouldn't like to have that on the wall controlling my central heating.
    Not bad for a couple of pounds.
    Sep 2011
    Ballarat
    65
    3,103
    You have the best scrap guy John.
    Good score.
    Phil
    Jul 2006
    Athelstone, SA 5076
    4,255
    That old Teddington t/stat is older than I am...not supprised it still works tho...they were pretty much in-destructible back in those days
    Jan 2004
    Mackay North Qld
    6,446
    A useful pick up for minimal cash.
    Dec 2005
    South Australia
    1,656
    Nice pick up ( did you find your piece of Aluminium)
    6,443
    Hi China,
    Quote Originally Posted by China View Post
    Yes I did, thanks for asking. I forgot to mention that I had. A chunk of 55 mm round bar about 35 mm long.
    I did start to machine it last night. I've faced off both sides and centre drilled it, ready to drill the hole for the TCG control spindle. The outside is a bit rough, so I hope that it will clean up without making it too small in diameter.
    Dec 2005
    South Australia
    1,656
    Just thought I would ask, many times I go to find some thing and come out with some thing(s) completely different
    Jul 2011
    Adelaide
    837
    I wish we had a scrap yard like that in South Australia, A couple of pounds wouldn't get me anything here.
  1. Deckel FP1 plus other goodies for sale.
    By KBs PensNmore in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 30th Apr 2018, 12:22 AM
  2. Scrap yard Mill
    By Metalman in forum METALWORK GENERAL
    Last Post: 12th Dec 2016, 06:56 PM
  3. Wrecking Photocopies for Goodies
    By Blu_Rock in forum METALWORK GENERAL
    Last Post: 28th Apr 2014, 05:59 AM
  4. scrap yard lathe
    Last Post: 14th Sep 2012, 09:40 AM
  5. Got my first lathe and other goodies :d
    By xXvapourXx in forum METALWORK GENERAL
    Last Post: 20th Nov 2011, 11:41 PM
