Results 16 to 16 of 16
16th Aug 2019, 11:04 PM #16Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
This style of surface grinder is inherently difficult to lift because of the lack of lift points. I have a "Robot" grinder which is similar to the Power and almost identical to the small B&S grinders.
I reluctantly drilled and tapped 2 M10 holes on each side of the base casting and bolted a piece of 75x75x10mm angle to each side and can now lift the machine safely and easily with perfect balance.
Power S3 Surface grinder
By Jayson in forum METALWORK GENERALReplies: 6Last Post: 7th Jan 2024, 02:37 PM -
Power Surface Grinder
By DSEL74 in forum ANTIQUE AND VINTAGE MACHINERYReplies: 20Last Post: 11th Nov 2016, 11:05 AM -
power surface grinder
By markgray in forum METALWORK GENERALReplies: 14Last Post: 28th May 2015, 04:20 PM -
Lifting surface grinder ????????
By shedhappens in forum METALWORK GENERALReplies: 9Last Post: 30th Oct 2012, 07:53 PM -
safe lifting points of hafco 960b lathe
By lather in forum METALWORK GENERALReplies: 35Last Post: 16th Aug 2010, 01:29 AM
