Results 1 to 8 of 8
Thread: Fish-mouthing rod or tube
23rd Jun 2019, 07:24 PM #1Most Valued Member
I'm making a large "clap-trap" for catching Indian Mynas. The frame is made from 8mm 304 SS. As I don't have TIG I have silver soldered the joints with 56% silver solder. To improve the strength of the joints I fish-mouthed the joints by securing the bar in a AXA tool holder and cutting the fish mouth with an 8mm solid carbide end mill (I don't own a milling machine). It works extremely well. As long as the end mill is the same diameter as the rod you get a perfect joint. The silver solder is expensive so a tight joint means I only needed a small amount to make the joint.
I'm sure I'm not the first person to use this method, but I thought I'd share it anyway. I'll certainly be using it again.Chris
23rd Jun 2019, 08:44 PM #2
Good on ya for doing something about the Mynas -vermin birds
Good idea on the birdsmouth too ?
56% percent silver. Can't be cheap? Is it a coated stick?
23rd Jun 2019, 08:58 PM #3Intermediate Member
- May 2019
- Tucson, Arizona, USA
- 46
Nice job Chris. I like your style.
David
www.desert-hybrids.com
23rd Jun 2019, 09:31 PM #4Most Valued Member
Thanks gents.
Grahame,
It's this stuff: https://www.harrisproductsgroup.com/...y-Silv-56.aspx
I think it comes in coated sticks, but I use this flux: https://www.harrisproductsgroup.com/...lack-Flux.aspxChris
23rd Jun 2019, 10:25 PM #5
Cant argue with someone catching those ferals.
Whilst a bit off topic, it relates toMynas.
Went to a job a while ago and asked why they had raw meat sitting on their picnic table. Response was it attract the magpies.
Apparently they do a good job of keepingMynas out of the yard.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
25th Jun 2019, 12:27 AM #6Most Valued Member
- Healesville
- 2,129
25th Jun 2019, 09:18 AM #7Most Valued Member
No thanks John, they are foul smelling creatures. A quick dose of CO and into the rubbish bin with them.
25th Jun 2019, 09:14 PM #8
Ah yes the good old council burial. On that topic, had to laugh recently cause our local council put a thing out on the media about just that topic. Since when did saying not to do something actually work!!!
How to get fish oil off lathe ways
By 19brendan81 in forum METALWORK GENERALReplies: 12Last Post: 21st Jun 2022, 04:15 PM -
u tube again
By morrisman in forum METALWORK GENERALReplies: 2Last Post: 4th Aug 2014, 10:42 AM -
U tube idea
By morrisman in forum METALWORK GENERALReplies: 9Last Post: 11th May 2014, 09:11 PM -
U tube favourites
By morrisman in forum METALWORK GENERALReplies: 37Last Post: 27th Feb 2012, 12:52 PM -
Fish oil
By seafurymike in forum METALWORK GENERALReplies: 13Last Post: 10th Feb 2012, 05:06 PM
