Results 1 to 5 of 5
Thread: Morse Taper MT2 and 2MT
19th Jun 2019, 10:03 AM #1New Member
- Maryborough, Qld
- 1
I'm about to purchase my first lathe.
The lathe's specs say the tailstock has a Morse Taper MT2.
According to the manual my drill stand has a 2MT Morse Taper (B16-2MT).
Is there any difference between an MT2 Morse Taper and a 2MT taper?
If there isn't (which I suspect) then I'll be able to use the drill's chuck in the lathe tailstock. If there is a difference then I'll have to by another chuck for the lathe.
19th Jun 2019, 10:07 AM #2
Two ways of saying the same thing.
19th Jun 2019, 10:40 AM #3
As said you will be able to share tooling
Using Tapatalk
19th Jun 2019, 11:28 AM #4Senior Member
- Dec 2011
- Rosebery/Eastlakes
- 115
Congratulations on your prospective purchase! Let the learning begin..
Sent from my SM-N960F using Tapatalk
19th Jun 2019, 11:36 AM #5Member: Blue and white apron brigade
An old timer at work used "MTx" for plugs (males) and "xMT" for the sockets (female) - or was it the other way around - can't remember.
I once held up an MT2 female to MT3 male adapter in front of him asked him what he would call it and he quickly said "2MT to MT3"
Clever when you think about it as long as you can remember which way around it is.
What is the Morse taper size ?
By auscab in forum THE HERCUS AREAReplies: 25Last Post: 3rd Feb 2018, 01:22 AM -
Morse Taper 1-3?
By goodwoody in forum METALWORK GENERALReplies: 19Last Post: 25th Nov 2014, 06:52 AM -
Adapting morse taper
By Tiger in forum METALWORK GENERALReplies: 16Last Post: 10th Jun 2014, 02:02 PM -
Morse taper question
By chambezio in forum METALWORK GENERALReplies: 12Last Post: 5th Feb 2014, 05:18 PM -
loose morse taper fix
By morrisman in forum METALWORK GENERALReplies: 15Last Post: 30th Sep 2012, 12:10 AM
