Results 1 to 9 of 9
    Jun 2016
    Sydney
    283
    Default Advice on adjusting an AL-50GA compound slide
    Yes, I know the poor old AL-50GA from the rabbits is the bottom end of the range, but I have had it for many years. Within its limitations, it works fine.
    Now I want to remove a small amount of backlash from the compound slide. The manual says to remove the two screws holding the spindle bracket and to remove the spindle. Then 'adjust the screw ring'. The accompanying diagram is totally obscure.
    I have removed the spindle bracket, slid the top part of the slide out of the way, and peered into the internals. Um ... WHAT screw ring?
    I can see a very small protrusion around the threaded shaft, but how to adjust that is a bit of a mystery to me! It is very narrow and it has one slot at the side which is almost useless without some very custom tool (not supplied), and it does not seem to want to 'adjust' anyhow.
    Help. Has anyone managed to do this?
    Roger Caffin
    Sydney
    Jun 2007
    sydney ( st marys )
    64
    4,887
    What is No7 in the parts diagram?
    Jun 2012
    SA
    1,649
    It's the backlash adjusting screw.
    Check page 19 of the following pdf:
    http://content.jettools.com/assets/m...55K_man_EN.pdf
    The worst that can happen is you will fail.
    But at least you tried.
    Jun 2016
    Sydney
    283
    Default Ask and receive
    Ask and ye shall receive! My thanks to both of you.
    The PDF version of the manual for the JET lathe has good clear grey-scale photos where my manual has a different and obscure photo which actually conceals the adjustment. The JET lathe is a little different in the turns-ratio adjustment box, but the rest of the lathe is pretty much the same. I have downloaded the PDF.
    OK, now I know what to adjust. I have tried to move that 'screw' but with no joy so far. Have you managed to adjust this? Should I remove the threaded shaft completely first? And what sort of tool have you used for this? All advice received with gratitude.
    Roger
    Sydney, AU
    Jun 2012
    SA
    1,649
    I have no experience with that lathe.
    My course of action would be to contact the Yahoo 9x20 group and ask the "how" question there.
    https://groups.yahoo.com/neo/groups/...01mOR-SxG3jj6y
    If they don't know, then I guess nobody does
    From past experience with Yahoo groups, I expect they will make you most welcome and answer your questions correctly.
    Cheers Rob
    Jun 2016
    Sydney
    283
    I had a look at that, but Yahoo! wants me to accept unsolicited ads from 3rd parties and tracking cookies from them as well. NO WAY!
    Yahoo! must be still living in the Dark Ages. With that sort of attitude towards possible subscribers, no wonder they are dying.
    Well, thanks anyhow.
    Roger
    6,444
    Hi Roger,
    It helps to set your browser to never remember history, not to accept third party cookies and to Block pop-up windows, Warn you when web sites try to install add-ons, and Prevent accessibility services from accessing your browser. Also use private windows.
    These settings work well for me, but then I don't use Mac or Windows or Android for that matter.
    HTH.
    Jun 2012
    SA
    1,649
    Hi Roger,
    HTH.
    AHHH. Another Linux user Good to see.
    Long time Mint user. Mint 19 in Mate is my current choice. LXDE has also been excellent.
    I fully agree with your suggestions. No drama with Yahoo.
    Cheers Rob
    6,444
    Hi Rob,
    Yes there are a few of us about Good to hear from you.
    I'm running Q4OS with Trinity desktop on an i7 with 10 Gb ram. Quite a dramatic change in speed compared to the AMD quad core Athlon with 4 Gb ram that I was using. That memory is now in the new machine along with a spare 2 Gb stick that I had. Not that its using any swap at all.
    I moved from Ubuntu simply because trying to keep up with the changes became a pain ! With Q4OS all the changes and updates are automatically fed to me and installed automatically subject to acceptance. Any fixes are rapidly sorted, very often before you realise that one is needed.
  1. New Visby compound slide disassembly advice
    By Flo in forum METALWORK GENERAL
    Last Post: 30th May 2019, 12:16 AM
  2. Compound Slide
    By bwal74 in forum THE HERCUS AREA
    Last Post: 10th Apr 2014, 12:20 PM
  3. How does the small compound slide come apart?
    By Com_VC in forum THE HERCUS AREA
    Last Post: 1st May 2011, 01:21 AM
  4. Compound slide problems.
    Last Post: 27th Jan 2010, 08:34 AM
