Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    May 2019
    Melbourne, Australia
    44
    Default Machining speeds
    Hi all, I'm a little confused about the speed I need to be turn the work piece on my lathe..
    My lathe is a lovely, well maintained Qualos, which as has a maximum of 648rpm according to the chart on the side. The machining calculators seem to think I need to be running at anything up to 2400rpm spindle speed and this speed goes through the roof if I'm using Carbide, instead of HSS.
    Am I missing something here?
    Jul 2016
    35
    1,522
    Nope carbide can just handle some insane surface speeds, those calculators are mostly designed to optimise tool life in CNC machines.
    You can run it slower but it won't give the amazing surface finish you get when really pushing it.
    May 2019
    44
    Quote Originally Posted by caskwarrior View Post
    Well, the old Qualos isn’t getting anywhere NEAR those speeds!
    Oct 2017
    Lismore, NSW
    58
    G'Day Davo,
    Here's a simple formula for spindle speeds; RPM = (300xV) divided by d, where "V" = cutting speed velocity in meters per minute & "d" is work diameter in millimetres. Approximate cutting speed velocities for some common materials using HSS are, Mild steel = 25 to 30 m/min, Brass = 35 to 40 m/min, Aluminium = 50 to 60 m/min, Cast Iron = 20 to 25 m/min. These are starting figures & vary according to the turning operation eg. screw cutting mild steel, the cutting speed would drop to around 5 to 8 m/min. If in doubt start at the lower end speed & increase to suit the application. If you are experiencing a built up edge on a HSS tool, it is often an indication that the cutting speed is too slow. Hope this helps.
    Regards,
    Don.
    Nov 2018
    Tasmania
    97
    Quote Originally Posted by Don@2480 View Post
    G'Day Davo,
    Regards,
    Don.
    100% agree with this rule of thumb
    For mild steel with HSS I use 9000/ diameter
    For anyone interested in where this comes from
    s = pi * D *R
    • s = surface speed ie 30 m/min for steel
    • pi = 3.14...
    • D is the cutter diameter
    • R is RPM
    Rearranging we get
    R = s / (pi * D)
    I like to use mm for cutter diameter, so adjust by 1000 gives
    R = 1000 * s / (pi * D)
    R = 1000 * s / (3.1415 * D)
    R = 318.32 * s / D
    And if you work steel s = 30 m/min
    R = 9549/D
    I round this down to 9000 in my head because it's easier to remember and close enough for what I do
    and I triple the values when using carbide as this tends to work with my machines
    I also translate this to lathe work where D is the work diameter
    May 2019
    44
    Thanks again, guys!
    May 2019
    44
    I've been running the old Qualos in top gear at 648rpm and the finish is MUCH better using the Carbide. so I was thinking as the motor is belt drive to the gear head, could I just change the ratio of the belt drive to get more rpm at the spindle?
    obviously if I double the size of the motor pulley, it would make top gear 1296rpm, BUT, will the old Qualos cop with that?
    Oct 2007
    Alexandra Vic
    69
    654
    Many of the earlier light duty lathes used white metal bushings for the spindle, and rely on a drip feed oiler or small oilcups for providing lubrication. This is quite viable if the machine is not expected to operate at maximum loads for entire industrial shifts, and the operator is good at maintaining oil levels. However if you take the spindle speeds beyond what the designer intended, you significantly decrease spindle bushing life, even with good oil maintenance.
    More recent lathes intended to operate at higher loads or speeds tend to have ball races or taper bearings to carry the loads and handle the speeds involved. There are a few models of Qualos lathes that range from light duty to medium duty, so it is hard to guess which model you have, but it would be a fair guess that winding the spindle speeds significantly would be detrimental to spindle bearing life.
    May 2019
    44
    Quote Originally Posted by malb View Post
    It's a 5 1/2" gearhead. tapered roller bearing on the chuck side and ball race on the others...
    7,189
    Davo, this is where a VFD is very useful.
    I tropical operate my plain bearing Hercus at the regular max speed of 1050rpm.
    However to perform a couple light finishing cuts on a job I top up the oil and run it up to 1400, even 1500 on say >12 mm diameter jobs..
    I've been doing that for some time - doesn't seen to have suffered any.
    A VFD helps in a lot of ways like being able to change the speed on the fly when parting.
    May 2019
    44
    It's funny, I spent forever trying to find a decent sized single phase lathe, only to find out I could have had 3 phase and just ran a VFD!
    Anyway, upgrading to a 3 phase motor and VFD maybe something I can consider for the future... until then I might just change the pulley on the motor!
    7,189
    Quote Originally Posted by Davo81 View Post
    Sure, once you put one on you'll wonder why you didn't do it earlier.
    May 2019
    44
    Well, I would have to debate whether I just buy a monster 3 phase unit and sell the Qualos on...
    Aug 2011
    Perth, Western Australia
    67
    362
    One thing to keep in mind when increasing pulley size to gain speed is the decrease in torque to the spindle. Too large an increase in pulley size could lead to decrease in cutting depth or ability.
    Tony
  15. #15
    May 2019
    44
    Quote Originally Posted by bts View Post
    Tony
    That’s true... I’ll give it a try, I can always put the smaller pulley back on.
  1. Spindle speeds
    By Chriso747 in forum THE HERCUS AREA
    Last Post: 17th Apr 2016, 10:53 AM
  2. RF-25 Spindle Speeds
    By Auskart in forum METALWORK GENERAL
    Last Post: 15th Jan 2012, 05:51 PM
  3. DM 45 Standaco speeds
    Last Post: 3rd Sep 2011, 08:09 PM
  4. Motor speeds
    Last Post: 12th Nov 2010, 09:45 AM
  5. Cutting speeds
    By Buncha in forum THE HERCUS AREA
    Last Post: 13th Oct 2008, 10:53 PM
