Results 31 to 34 of 34
12th Jun 2019, 08:39 PM #31Golden Member
- Aug 2015
- Melbourne, Australia
- 843
Wow - I picked up about 30 NOS HSS blades for it for like $60. Might last me then ....
16th Jun 2019, 07:51 PM #32Golden Member
- Aug 2015
- 843
Solved
Steve, Shed, Gavin, and all who offered advice: we're finally there - it is working now, and very well to boot.
I made this 'cap' for the valve thingo. Yes, I made it badly, but it was an experiment, so I wasn't exactly caring about accuracy with the dremel. It is a simple cap with a through hole and four slits.
A ball bearing went into the thingo and the above was glued (red locktite) to the top - slits down into the thingo.
When cured-ish I gave it a go with ISO 68 hydraulic oil (being careful to make sure I had no air in the system) and it worked a treat. After lifting the ram it lowers slowly - much faster than Steve's 5mins per 100mm, but very usable. The return stroke lift is probably about an inch at the end of the ram.
I guess with the ISO 68 being reasonable 'thin' it just find its way past the ball bearing, and also I think, past the pistons.
It may be not very well made (being yet another experiment) but it works so it stays - as is.
Very happy. Thanks again all.
Greg.
PS. As a side note - I phoned Hercus to see if they had original plans or anything. Nope. They have no plans for any old stuff like this. Lost to time and office moves over the years.
18th Nov 2022, 08:07 PM #33Novice
- Nov 2021
- Brisbane Qld
- 11
hydraulics-
Hey so i had mine apart today, I can confirm mine has the original brass fitting in the bottom, and it has a captured ball bearing in it, which is held in place by a small pin pressed in across the oriface to capture it, Im guessing in yours the pin has rusted away or gone walkabout somehow.. mine was still there, i just forgot to take pics of it. mine had a broken rod between the eccentric and the pump body, so today was the day i fixed it and it works like new! cheers, Levi.
18th Nov 2022, 08:10 PM #34Golden Member
- Aug 2015
- 843
No pics! Gutted!
But, okay. Sounds like I was on the right track. Well done for getting yours operational.
What oil for Hercus hacksaw hydraulic lifter - and position of eccentric?
By StrayAlien in forum THE HERCUS AREAReplies: 0Last Post: 27th May 2019, 03:36 PM -
Hercus power hacksaw
By Johnny Rocker in forum THE HERCUS AREAReplies: 11Last Post: 23rd Apr 2019, 10:09 PM -
Hercus Power Hacksaw
By lamestllama in forum METALWORK - Machinery, Equipment, MARKETReplies: 15Last Post: 24th Feb 2019, 10:23 AM -
Hercus hacksaw
By sheppo in forum METALWORK GENERALReplies: 1Last Post: 29th Jan 2012, 09:48 AM -
Hercus Hacksaw
By Godzilla98 in forum THE HERCUS AREAReplies: 0Last Post: 12th Mar 2009, 10:20 PM
