Results 1 to 15 of 29
Thread: Acetal Faced Machinist Hammer
2nd Jun 2019, 01:17 PM #1
G'day all,
What's the best method of attaching black acetal to a machinist hammer(s) that I'd like to make.
Thinking of making two, one the middle part brass faced with two acetal ends and one aluminium with two acetal ends.
Jim
2nd Jun 2019, 01:21 PM #2Most Valued Member
- 4,890
Screw thread.
2nd Jun 2019, 01:27 PM #3
2nd Jun 2019, 02:22 PM #4Most Valued Member
I think this is what you are intending making: https://www.youtube.com/watch?v=Q6X4HIDmJsA
He puts the male thread on the Acetal. I would put it on the brass.Chris
2nd Jun 2019, 02:26 PM #5Most Valued Member
2nd Jun 2019, 02:27 PM #6Most Valued Member
- 4,890
Thread both.
2nd Jun 2019, 02:31 PM #7Most Valued Member
very droll.
2nd Jun 2019, 05:31 PM #8Most Valued Member
This thread inspired me to make a knocker similar to that shown in the video. I used M10x1.5 thread. If I can find some lead I'll replace the ali end with lead. Can you tap threads in lead?
2nd Jun 2019, 08:19 PM #9Member: Blue and white apron brigade
- 7,188
Here is my brass and Al hammer.
The threaded rod is SS.
Wood from the branches of a red gum that grew outside the shed for 30 years before being taken down.
3rd Jun 2019, 12:45 PM #10Most Valued Member
- 4,258
No
But tin the brass end. make a mold and pour lead into it. The lead fuses with with the tin. I used hard lead in my hammer.
//metalworkforums.com/f303/t201...ghlight=hammer
3rd Jun 2019, 12:54 PM #11Most Valued Member
Thanks eskimo. I did a bit of reading online and the consensus was it's a nightmare to tap it. I'm going to buy a scuba diver's weight and have a go at casting it.
3rd Jun 2019, 01:07 PM #12
3rd Jun 2019, 03:26 PM #13Intermediate Member
- May 2019
- Tucson, Arizona, USA
- 46
Hi Jim,
Here is a hammer I made that has removable ends. The 4140 alloy steel body is bored on each end to accept the stems, which are each secured with a single set screw. This particular hammer is actually for sheet metal shaping, and the removable ends are actually CP dies used for metal shaping. I manufacture 13 different die shapes in both black 6/6 nylon and 4140 Heat Treated alloy steel. If I were just installing flat hammer faces then I would make the stems a press fit into the body. I use this method for some of the specialty hammer dies I make for Pullmax and Planishing Hammers.
You can see some of this tooling here:
David
http://www.desert-hybrids.com/id71.html
CP Hammer 1.jpg CP Hammer 2.jpg CP Hammer 3.jpg CP Hammer 4.jpg CP Hammer 5.jpg CP Hammer 6.jpg
3rd Jun 2019, 03:33 PM #14Intermediate Member
- May 2019
- 46
3rd Jun 2019, 04:01 PM #15Member: Blue and white apron brigade
- 7,188
a hammer
By eskimo in forum METALWORK GENERALReplies: 8Last Post: 22nd Feb 2015, 05:35 PM -
Black acetal leadcrew nuts
By morrisman in forum METALWORK GENERALReplies: 1Last Post: 13th Nov 2013, 09:01 PM -
How big a hammer do you need?
By Michael G in forum METALWORK GENERALReplies: 31Last Post: 24th Nov 2012, 06:22 PM -
Online sources for Acetal 'Delrin' solid rod?
By martrix in forum METALWORK GENERALReplies: 15Last Post: 21st Feb 2010, 01:14 PM -
Delrin or Acetal... where can I buy some?
By Malfie in forum METALWORK GENERALReplies: 3Last Post: 11th Jul 2007, 06:49 PM
