Results 1 to 9 of 9
Thread: Parkanson bandsaw
31st May 2019, 10:39 PM #1Most Valued Member
- 2,673
Parkanson bandsaw
Couldn't resist picking up this cheap bandsaw.
The original photos didn't give much idea of the scale, but I started to get that "what have I got myself in for" feeling when arranging pickup and the seller said it was 1.3T !!
My ute is ok for 1.5T payload, but it's a bit higher than I'd have liked. The ute tray is 2.7m long to give some perspective...
Going to be interesting unloading it....
31st May 2019, 11:05 PM #2Most Valued Member
That's a nice big hands as!
Nice Ute too. Is it a land rover?
31st May 2019, 11:17 PM #3Most Valued Member
- 2,673
Yup, it's a Landrover - a 1998 130 single cab.
LR's are one of my other sicknesses
1st Jun 2019, 12:11 PM #4
Nice machine, you must have some serious cutting to do.
Using Tapatalk
1st Jun 2019, 12:25 PM #5Most Valued Member
- 2,673
1st Jun 2019, 12:40 PM #6
I've just got a 7x12 as a second saw. Blade prices jump up but I think it's the perfect home shop size being able to cut 7x12 steel, and it can be used vertically which I sometimes use.
If you go through it it might make some good money to the right shop.Using Tapatalk
1st Jun 2019, 03:53 PM #7Most Valued Member
Nice find, Steve. What is it's cutting capacity???
I used to like Landrovers also, and I found the cure for it. Work on them, some required the use of Imperial, Metric and Whitworth spanners!!!!
2nd Jun 2019, 12:57 AM #8Most Valued Member
- 2,673
I'm not sure Kryn. Looks like it's got enough travel and opening to do about 12x12.
Haven't found an ID plate on it yet.
5hp motor, hydraulic clamping and raise/lower. Came with 4 brand new blades and 20 years of grime.
I think it's actually hydraulic blade drive too as it's got a rotary hydraulic valve underneath the speed control knob.
8th Jun 2019, 12:43 AM #9Most Valued Member
- 2,673
Decided to give it a hit with degreaser and a pressure washer while it was still on the ute. Still looked filthy when I finished but the ute ended up covered in muck so I know the saw has a bit less on it now.
Seems to be what is referred to as a "hitch feed" type. The input side clamps the stock then moves it towards the blade. It has two main motors, one for the blade and the other for the hydraulics. Likely there's a separate coolant pump but I haven't eyeballed one yet.
Unfortunately the feed clamp has a broken jaw, which had been repairs in the past but broken again.
Ran out of lift height with my gantry while unloading it, so had to end up up using 2 blocks, a chain block and a lever one.
Finally back on the ground..
Parkanson Power Hacksaw
By Mk1_Oz in forum METALWORK GENERALReplies: 50Last Post: 14th Nov 2020, 07:17 PM -
Parkanson Power Hacksaw 45 angle cut
By TootsieB in forum METALWORK GENERALReplies: 27Last Post: 23rd May 2019, 01:53 PM -
SOLD: PARKANSON Power Hacksaw
By harty69 in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 15th Jul 2013, 07:52 PM -
Parkanson power hacksaw
By Dave J in forum METALWORK GENERALReplies: 60Last Post: 18th Feb 2012, 08:09 PM -
parkanson
By parkinson in forum METALWORK GENERALReplies: 10Last Post: 2nd Mar 2011, 08:59 PM
