Results 1 to 15 of 15
Thread: Lathe feed controls
27th May 2019, 07:06 PM #1Gear expert in training
- 34
- 1,075
Lathe feed controls
So far in my fairly short metalworking career I've seen quite a number of different lathes (probably about 10 between work and school) and they all seem to have similar controls for the feed; a direction selector, an axis selector and an engagement lever (and they're all in different places and inconsistent as to which direction pull/push goes ). Except for the Tos Trencin lathe at work. This thing has, I reckon, the single best control system ever devised; a single lever that you just push in the direction you want to go and a button on top for rapid travel as well.
I'm assuming the only reason everyone doesn't do this is because it's patented, but man I wish it was more common.
27th May 2019, 07:43 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
My CVA has quite a good system, two totally independent clutched levers and a reversing pull push control. I haven't found any use for feeding both at once but one day I might try power chamfering.
My pet hate is lathes that have the feed reverse lever all the way at the back of the headstock.
27th May 2019, 08:44 PM #3Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
We have a Colchester and a Chinese lathe with a joystick on the right hand side of the carriage for the feed, with a button in the center of the joystick for the rapid. best system i have used.
Worst is our Taiwanese lathe with the feed handle at the the bottom left or the carriage, right in the line of the hot chips spraying off the tool.
27th May 2019, 09:11 PM #4Gear expert in training
- 34
- 1,075
Pic? Or model number so I can look it up?
Yeah, controls in the way of chips is just poor design. If they have to be there, at least include a chip guard
27th May 2019, 10:03 PM #5
I like how the hand wheel is on the right, my Okuma hand wheel is on the left with chip guard but would much like a right hand wheel.
28th May 2019, 06:02 PM #6Gear expert in training
- 34
- 1,075
The 6 brands we have at work all have the handwheel on the right, the only other one I've seen on the left is the Leblond Makino at school. Very annoying position and not even guarded.
28th May 2019, 08:20 PM #7Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
colchester magnum, the feed control is the only good design feature on that lathe.
Colchester Magnum Lathe
28th May 2019, 09:13 PM #8Most Valued Member
- Charlestown NSW
- 1,669
We tend to have right hand sided hand wheels because we are part of the old British empire and that's what the Brits used. The Americans (and I think a lot of Europe) go for the other style. I pretty much have only ever used right hand side hand wheel machines (except for the old Hercuse's at school back in the 1970's) and I don't think I could change over now.
It wouldn't be too bad while everything was going well but in the event of something starting to go not so well, my instincts would take over and I would be winding the RHS hand wheel clockwise and the LHS anti clockwise. hmmmmm.
pete
28th May 2019, 09:34 PM #9Gear expert in training
- 34
- 1,075
I dunno...we've got English, Italian, Japanese, Czech and Taiwanese lathes and they're all on the right. Seems to be a bit whatever they felt like at the time
28th May 2019, 09:48 PM #10Philomath in training
- 6,541
My lathe is English, but the wheel is on the left - although it is an evolution of a US lathe. I've made up a free standing deflector shield to stop the chip shower. John Stephenson had a similar lathe and hard bolted a deflector to his in roughly the same position. It is a (literal) pain sometimes, but then again if that is all that is wrong with it...
28th May 2019, 09:55 PM #11Most Valued Member
- Charlestown NSW
- 1,669
A lot of the better quality machines can be ordered with right or left hand wheels (or at least they used to be) so Brits and Aussies tended to order the right hand version while the USA favours the left. I have no idea why apart from what I said before . Maybe the yanks went for the left just because the poms liked the right.
Heres another question that I've always wondered about and no one has ever been able to answer very well.
Why do all manual lathes (not vertical lathes or cnc machines) have the head stock on the left hand side when looking at the front of the machine? A machine built the other way would still work.
I've seen horizontal borers that are controlled from different sides.
peter
28th May 2019, 10:04 PM #12Gear expert in training
- 34
- 1,075
29th May 2019, 09:02 PM #13Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
29th May 2019, 09:22 PM #14Most Valued Member
- 4,887
Is there not a duck board to stand on?
Have you thought of placing some type of removable guard , cardboard or similar to catch the runoff and direct it back to the pan?
29th May 2019, 09:51 PM #15Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
No duck board, I found a piece of sheet metal that deflected some of the coolant back into the pan but it didn't protrude far enough to catch it all, and it had pieces cut out of it. I also had to use a tool holder across the compound as a bridge to stop coolant reaching the hand wheel and pouring onto the floor
AL960B manual and controls
By jvb in forum METALWORK GENERALReplies: 13Last Post: 20th Mar 2015, 05:28 PM -
CQ6230A Lathe power feed speed
By dalvsdkg in forum METALWORK GENERALReplies: 14Last Post: 19th Jul 2014, 02:45 PM -
Adjusting Lathe Feed Stop
By Oldneweng in forum METALWORK GENERALReplies: 24Last Post: 4th Jul 2012, 09:49 PM -
Tokentools alupulse tig - controls
By steran50 in forum WELDINGReplies: 8Last Post: 8th Jun 2012, 10:39 PM -
TIG Controls explained.
By 19brendan81 in forum WELDINGReplies: 7Last Post: 28th May 2009, 01:22 PM
