Results 16 to 19 of 19
6th Jun 2019, 08:49 AM #16Member: Blue and white apron brigade
- 7,183
7th Jun 2019, 05:43 PM #17Member: Blue and white apron brigade
- 7,183
Here is the first of the interlocks.
Stainless steel push rod (pr) is attached by a thread to the toggle handle that locks the table to the DP column.
MI - Mains in
MO = Mains out
MS - Main switch
mS = Micro switch
PR -= Power resistors for the LED.
When table is locked by toggle handle "pr" is "in" and de-activates the micro switch - cutting power to the linear actuator
Below show the main power switch and the LED indicator.
When the red LED is showing this means it's safe to use the actuator. (Yeah I know should have use a green one but I have heaps of reds - may swap it around one day)
Here what it will look like behind the DP table in its normal position.
8th Jun 2019, 06:01 PM #18Member: Blue and white apron brigade
- 7,183
All done. Well enough to be able to use it anyway.
Still deciding what to do about the potter interlock and the pressure switch up/down. Kinda like the quirky nature of how they are - might leave them as they are for a while.
12th Dec 2019, 01:45 AM #19
Hi Bob, since I clicked on the wrong icon first time around, I clicked the right one this time
Thanks for the pictures.Best Regards:
Help please Welding a bolt to my table saw - height winder threads have stripped
By barrysumpter in forum METALWORK GENERALReplies: 24Last Post: 4th Apr 2019, 10:30 PM -
Ifanger Threading Tool - Replacement Cutter Height Adjustment Screw - Suitable Steel?
By Anorak Bob in forum METALWORK GENERALReplies: 12Last Post: 24th Sep 2017, 05:16 PM -
Optimal table height for Milling machine
By oohsam in forum METALWORK GENERALReplies: 15Last Post: 22nd Feb 2014, 10:17 PM -
Tailstock height adjustment
By Finnowa in forum THE HERCUS AREAReplies: 3Last Post: 3rd Oct 2013, 11:47 PM -
Tapered Gib Adjustment
By Anorak Bob in forum METALWORK GENERALReplies: 8Last Post: 14th Nov 2011, 08:21 PM
