Results 16 to 18 of 18
Thread: Lathe 3-jaw Chuck Wear
3rd May 2019, 06:25 PM #16Golden Member
- Vic
- 48
- 544
I am using the wood router with grinding wheel to do both "internal" and "external" and it seems to work for me...
7th May 2019, 11:39 PM #17Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
I finally located the fixture that I used to hold the jaws for grinding, it has pins that use the slot in the jaw as one datum and another pin that registers against the step jaw.
The process involved to achieve good results is time consuming and begins with disassembling the chuck, cleaning, removing any burrs or bruising,lubricating and reassembly/mounting.Chuck Jaw Grinding Fixture.JPGFixture and Clamps.JPGFixture with 5 inch jaw..JPGFixture with 8 inch jaw.JPG
8th May 2019, 04:25 PM #18Golden Member
- Apr 2009
- Kingswood
- 930
Following is a photo of the subject chuck jaw.
I have 4 chucks, all with tip radii approx 25 mm:
- subject 3-jaw tip is 7 mm wide and shows evidence of previous grinding.
- new 3-jaw tips 4.5 mm,
- old 4-jaw tips 3.5,
- new 4-jaw tips 4.5 mm.
So, I plan to surface grind the subject tips down to about 4 mm or so before the lathe grind.
I wonder if some of the problem is the tips are now through the case hardening layer ?
Welcome comments on the situation with chuck jaw hardening.
Techo1, interesting to see the description of grinding on a T&CG.
My approach would have been similar to that described by caskwarrior, but using an angle plate.
Thanks jackaroo for the photos, my clamp ring will be similar.
John
Angle grinder wear..
By russ57 in forum METALWORK PROJECTSReplies: 20Last Post: 4th Mar 2018, 08:36 PM -
Feed Screw Wear
By Oldneweng in forum METALWORK GENERALReplies: 11Last Post: 12th May 2017, 04:52 PM -
Bed wear
By Murray77 in forum THE HERCUS AREAReplies: 6Last Post: 18th Mar 2015, 08:36 PM -
Lathe countershaft wear
By kenny_10 in forum METALWORK GENERALReplies: 8Last Post: 14th May 2014, 10:53 PM -
Lathe bed wear
By morrisman in forum METALWORK GENERALReplies: 5Last Post: 15th Sep 2012, 11:12 PM
