Results 1 to 15 of 20
22nd Apr 2019, 11:02 AM #1Intermediate Member
- Mar 2019
- Rockhampton
- 28
Can you use a drill Press as a simple Mill?
This might be the Dumbest question on the forum but as a newbie I have to ask it anyway..... Just wondering if you could use a drill press for milling operations? What I was wanting to do is to cut some slotted holes in a piece of angle. My thoughts were to use a Colet to hold an end mill and use a cross slide to cut the slots. Am I just preparing to kill myself or is this an OK procedure. I know it would be better to have a proper Mill but I don't and was trying to work out a way I could do this rather than drilling holes and filing the slots out.
22nd Apr 2019, 11:15 AM #2Senior Member
- Dec 2010
- Syd
- 492
I think they say the drill press is the most dangerous piece of equipment in the workshop. I know I've done some silly things on them, so won't stop you!
Probably not too good for the quill with side load I'd imagine. Arboga did make a mill/drill thing that was designed for light stuff like that however.
22nd Apr 2019, 11:17 AM #3Member: Blue and white apron brigade
- 7,183
By all means try it but my bitter experience is you will end up with.
Damage to your drill - unconstrained Morse taper will fall out an break stuff including you. You could end up increasing any half decent run out you had to begin with. Mills uses a drawbar to retain the chuck - drill presses can't normally do this.
Lots of Broken bits
Ugly looking finishes
Slots that vary in size all over the place
These problems are largely caused by the fact that most drill press cross slides are just not heavy or solid enough to hold the work piece steady/form under the side pressure of a turning bit. the result is chatter and thats what leads to these probs. I started with a cheap 4" cross slide (Ha - dreaming mate) and thought my problems would be solved by a 5" slide but still dreaming. Then I tried a small cross side table - OK for wood but still not good for metal.
22nd Apr 2019, 11:32 AM #4Most Valued Member
- Healesville
- 2,129
22nd Apr 2019, 11:48 AM #5Intermediate Member
- Mar 2019
- Rockhampton
- 28
Thanks Everyone... Question answered..... Will need to come up with another solution... Any suggestions? Or is a mill the answer? Would love a mill but space is a real issue for me.
22nd Apr 2019, 12:31 PM #6Most Valued Member
22nd Apr 2019, 01:28 PM #7Member: Blue and white apron brigade
- 7,183
A small mill about the size of drill press was all I could squeeze into my shed but the difference between it and my DP (which is a Heavy Duty DP with a 1.5HP motor) is like chalk and cheese.
The motor on my mill is only 1/2Hp and while the work envelope is small compared to a full size mill its fine for small stuff and for short/small slots, flats etc.
22nd Apr 2019, 05:39 PM #8Golden Member
- Mar 2009
- 54
- 825
Hi Gaza,
While I wouldn't recommend using your drill press as a mill there is absolutely no reason you can't use a slot drill to cut a series of holes which you can then file out to make your slot.
The main advantage of using a slot drill is that a normal drill bit will wander into an adjacent hole if its too close, a slot drill will drill straight down which means you can overlap your holes leaving less to file later.
You need to have your stock securely clamped so it can't move because a slot drill will not centre like a drill bit and will tend to pull the material being drilled around at random until it bites.
Of course you can always use a normal drill bit you just need to have your holes further apart and do a bit more filing.
Greg.
22nd Apr 2019, 06:52 PM #9Most Valued Member
- Charlestown NSW
- 1,669
Gaza.
How thick is the angle,
How many & how big are the slots you want?
Also how often are you going to want to do them?
If the answer is - up to about 4 mm thick, Not many, not very big and not very often then I'd just be marking them out accurately, drill out as much as you can, then set it up securely in a vice and cut out the remainder using a sharp cold chisel. Set it up in the vice so the line you want to cut to is level with the top of the vice jaw. Use the top of the jaw as a cutting guide
Finally dress up with a file. Std angle is not very hard or tough so it wouldn't take very long.
peter
22nd Apr 2019, 07:06 PM #10Member: Blue and white apron brigade
- 7,183
Depending on the length of the slot, the following is an alternative for "blue&white apron style" slots .
Before I got my mill I cut dozens of longer slots in up to 6mm thick material by drilling a 6 mm hole at each end of the slot and then cutting out the waste with a thin kerf cutting wheel, and then grinding or filing out any excess.
For short slots in thicker steel the wheel needs to be small, but there comes a point where it's not possible to get the wheel through the material as slot length limits penetration.
I used a thin kerf wheel in an old WW table saw to cut a dozen 8 mm wide slots up to 450 mm long in 50 x 3 mm angle. Even though I have a mill I would still use this method today if precision is not required as it would be way quicker than my mill would be at doing this.
22nd Apr 2019, 10:14 PM #11Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,836
You guys will likely say this is rubbish but its afordable to be either a bench drill or something else if it doesnt mill
Small in size cheap on price u might even be able to hack it with a decent motor
https://www.ebay.com.au/itm/220V-Ben...gAAOSwMGVaUEin
22nd Apr 2019, 11:25 PM #12Senior Member
- Oct 2015
- melbourne
- 473
Probably ok for pcbs and the thin wood as it claims.
Probably not ok for steel...
For a drill press..
https://sydneytools.com.au/product/b...xoC7HwQAvD_BwE
Still not a mill though.
Russ
22nd Apr 2019, 11:28 PM #13Member: Blue and white apron brigade
- 7,183
I wouldn't even buy it as a drill.
22nd Apr 2019, 11:31 PM #14Most Valued Member
- Aug 2009
- 1,836
It may be worth a hack maybe put some Japanese bearings in it with a small 240v electric motor hanging over the top on a variac but that would be another $150-$200 on top of the machine
23rd Apr 2019, 12:17 AM #15Diamond Member
- Aug 2006
- 1,105
gazza2009au: It's hard to tell if you are joking or being serious sometimes. lol
Restoration Projects - Tough Drill Press - Dawn Drill Press - Record Pipe Vice
By bwal74 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 10th Feb 2019, 03:11 PM -
Mill off ccenter on drill press?
By 20GT in forum METALWORK GENERALReplies: 8Last Post: 8th Aug 2017, 07:50 PM -
Simple way to drill a clean edged hole.
By BobL in forum METALWORK GENERALReplies: 7Last Post: 10th Jan 2017, 08:19 AM -
A Simple Tramming Ring for the Mill.
By Anorak Bob in forum METALWORK GENERALReplies: 54Last Post: 27th Feb 2013, 01:31 AM -
Simple Drilling Attachment for Mill
By Anorak Bob in forum METALWORK GENERALReplies: 0Last Post: 21st Dec 2010, 07:22 PM
