Results 1 to 8 of 8
Thread: Bearing spin
2nd Apr 2019, 06:04 PM #1Senior Member
- Nov 2012
- Mid North Coast NSW
- 422
Bearing spin
My mini lathe's aluminium multi step pulley has two large (47mm) bearings in its hub.
I am replacing them right now. The bearing are a fairly neat fit but both bearing outers will spin inside the hub if I try them with my fingers.
What's the correct procedure here ? A smear of Loctite ? I have some of the blue Loctite.
2nd Apr 2019, 06:39 PM #2Philomath in training
- 6,540
Loctite and others make a product called bearing locker (or similar). I think the loctite number is 684. Much better stuff to use.
2nd Apr 2019, 06:48 PM #3Most Valued Member
- 4,887
Is there any damage to the bearing surfaces?
If the outer races are spinning on their machined surface of the housing maybe that is the way it was intended, might pay you to measure before attempting to fix them in place.
2nd Apr 2019, 07:22 PM #4Senior Member
- Nov 2012
- 422
No actual damage as such like galling or scoring, just smooth where the outer sits.
But why would they design it that way ? Allowing it to spin would wear out the housing. I'm assuming of course that at some time in its life the bearings jammed and spun in the housing.
These bearings are open type so I will have to grease them.
I don't have any proper internal measuring tools by the way. Only verniers. Must get some one day, it's on the list.
PS Come to think of it....See the photo? there's a spacer between the bearings. Well the hub with the bearings on just slides all the way in quite easily, not a press fit at all. If the place where the bearings sit inside the pulley is worn then the space between would be tight, right, but it isn't. So I think you might be right, that it's the way it's intended (prob for easy removal to grease it) and I should just go ahead and fit it like it is.
2nd Apr 2019, 10:14 PM #5Senior Member
- Nov 2012
- 422
I went ahead and fitted it all together with grease. Putting a thin smear of the grease inside the pulley housing appeared to tighten up the bearing outer enough to prob prevent slippage.
I'm quite surprised at the brand new SKF bearings I put in it. They're really noisy.
3rd Apr 2019, 12:42 AM #6
Hi Phaser,
You might find that the bearings should be oiled rather than greased. Grease will have a tendency to cause the bearing to spin in the housing simply because its is much thicker than oil. Also belt tension and the friction it causes against the bearing outer will tend to stop it skidding.Best Regards:
3rd Apr 2019, 01:58 AM #7Golden Member
- Cairns, Q
- 666
Have a look here:
Shaft & Housing Fits | NTN Bearing
for information on ball bearing fits, particularly paragraphs 3 and 4. It seems likely that your bearing fits were designed that way.
Frank.
4th Apr 2019, 02:42 PM #8Senior Member
- Nov 2012
- 422
I used a general purpose grease which is not a heavy type.
It seems to be running fairly good. I'm just keeping an eye on temps when I use it to gauge what's going on.
The same for the headstock cos I thought it was a little tight so I backed off the bearings a little. It looks to cut ok so the bearings aren't too loose, I might have set it just right I hope.
In the process of making a steel stand for it now.
Bearing
By WesP in forum METALWORK GENERALReplies: 4Last Post: 25th Oct 2014, 12:16 PM -
Frozen Spin Index Spindle
By electrosteam in forum METALWORK GENERALReplies: 7Last Post: 16th May 2013, 02:36 PM -
Spin Test
By Stustoys in forum METALWORK GENERALReplies: 17Last Post: 18th Apr 2013, 11:58 PM -
Scraping, the spin test.
By Ueee in forum METALWORK GENERALReplies: 10Last Post: 5th Mar 2013, 11:07 AM -
bearing pre load
By morrisman in forum METALWORK GENERALReplies: 12Last Post: 4th Nov 2011, 03:52 PM
