Results 1 to 14 of 14
29th Mar 2019, 10:38 AM #1Most Valued Member
- Jul 2016
- 35
- 1,522
Source for 20degree pressure angle 10dp involute gear cutters
I'm having a very hard time finding a source for 20degree pressure angle 10dp involute gear cutters. All the import stuff and second hand eBay cutters are all 14.5degree. I need to cut 22, 24, 26 tooth gears. Does anyone know of a source?
There are some US manufacturers but none are willing to ship out here. Ideally a used tooling place would be great.
Thanks everyone
29th Mar 2019, 10:45 AM #2Pink 10EE owner
- 6,218
Depending on accuracy required, why not single tooth cut them with a cutter made via the button process.
OR CNC with gearotic to make the g-code.Gold, the colour of choice for the discerning person.
29th Mar 2019, 10:48 AM #3Most Valued Member
- Jul 2016
- 35
- 1,522
These are for a screw cutting gearbox, so the tooth form probably isn't critical but the surface finish and pitch accuracy are important. Do you have a link to a description of the two button process? I've heard about it before but never used it.
29th Mar 2019, 11:36 AM #4Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
There are any number of new metric 20° PA gear cutters available on AliExpress. Could they be used as a work around considering the end use of the gears?
The 2 button system is covered in Ivan Law's gear cutting book and Sir John covered the system in several articles which will be dotted around the net.
29th Mar 2019, 11:52 AM #5Most Valued Member
- Jul 2016
- 35
- 1,522
Ahhh yep I have found a good article by john, I think that's worth pursuing for sure.
Does anyone in Melbourne have a copy of Ivan laws book I could photocopy? Or know where I can get a copy? I'm in a bit of a rush on this one
I don't think a module gear will do as I have a lot of money invested in the long cluster gear I have had made, hardened etc
29th Mar 2019, 12:03 PM #6Senior Member
- Aug 2012
- Greenmount, W.A.
- 70
- 275
[QUOTE=caskwarrior;1948014]Ahhh yep I have found a good article by john, I think that's worth pursuing for sure.
You can download a pdf copy of Ivan's book from US Archives. Quality is not good, but reading it may help you to proceed with your project and buy a copy. You will find it here:
https://archive.org/details/Workshop...s_Gear_Cutting
Regards,
Alan.
29th Mar 2019, 05:37 PM #7Pink 10EE owner
- 6,218
John Stevenson was the guru on HSM for this sort of work A form tool for gearcutting
29th Mar 2019, 06:42 PM #8Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
Ash Gear & Supply TEL:248.374.6155 FAX:248.374.6255 - Gear Cutting tools the same day!
Ashgear in the USA ship to Australia. We have bought a few cutters off them at work. Only catch is you have to pay by wire transfer.
29th Mar 2019, 07:21 PM #9Member
- Oct 2017
- Lismore, NSW
- 58
Caskwarrior,
You could try Tracey Tools LTD ([email protected]). They are a UK company & their service is very good. I have bought quite a few 20˚PA, gear cutters from them at a fraction of the cost of elsewhere. Some were second hand but had been sharpened correctly & all are UK made.
Regards,
Don.
29th Mar 2019, 07:34 PM #10Most Valued Member
- 2,671
There are hobs on eBay from the U.K. if that's of any use.
29th Mar 2019, 07:50 PM #11
I thought that "Module" and "DP" were two ways of describing the same thing ?Best Regards:
29th Mar 2019, 07:54 PM #12Senior Member
- 112
Caskwarrior, It might be worth a call to Mick Moyle's in Sydney. They have all kind of stuff, both new & SH.
Chas.
29th Mar 2019, 08:27 PM #13Philomath in training
Yes...and no.
DP (Diametric Pitch) is the imperial way of specifying gears. Module is the metric way. (DP= M/25.4 is the relevant formula I think)
Most usually DP system gears have a 14 1/2 degree pressure angle and Module have 20 degrees (although pressure angle is independent of system)
So while a 10DP gear is almost the same as a M2.5 gear, it's not quite.
Ivan Law's workshop practice book on gears explains it in greater detail.
29th Mar 2019, 09:01 PM #14
Hi Michael,
Thank you for that explanation!
I do have Ivan's book, though I've not really studied it in any depth. I've not made any gears so its not been at the top of the list.
Obviously I've misunderstood the distinction between imperial and metric measurements and made a poor assumption.Best Regards:
scrounging about: 10dp cutters and a flat belt
By StrayAlien in forum METALWORK GENERALReplies: 5Last Post: 29th Aug 2017, 11:35 AM -
Sketchup Involute gear Plugin : Export 3d print file
By steamingbill in forum METALWORK GENERALReplies: 3Last Post: 11th Feb 2016, 09:30 PM -
Back gear pressure angle
By morrisman in forum THE HERCUS AREAReplies: 9Last Post: 23rd Oct 2014, 10:11 PM -
involute cutters for hercus gears
By tanii51 in forum THE HERCUS AREAReplies: 2Last Post: 12th May 2013, 06:32 PM -
suitable surplus source for right angle worm drive gear box ?- power hacksaw
By desbromilow in forum METALWORK GENERALReplies: 7Last Post: 6th Dec 2012, 05:45 PM
