Results 1 to 14 of 14
30th Dec 2018, 11:41 PM #1Golden Member
- Jul 2011
- 837
Macson surface grinder wheel removal question.
Hi I have a recently purchased Macson miniature benchtop surface grinder. I would like to change the grinding wheel. But I am not sure what I am looking at in this photo and how to undo it.
Anybody have one of these and know?
31st Dec 2018, 12:13 AM #2Most Valued Member
I think you'll need to make a couple of spanners to fit the nut. A bit hard to see what thread it is but I'd take a guess and turn it anti clockwise as per a normal nut. Once you've got that off, you'll probably find the arbor has some sort of device to enable a puller to be attached.
I have a vague recollection that Michael made a removal tool for a grinder, whether it was for his Jones and Shipman, I can't be sure.
31st Dec 2018, 12:56 AM #3China
- Dec 2005
- South Australia
- 1,658
If I am correct you need a two prong spanner to fit the centre and remove the wheel and hub, then disassemble the hub to change the wheel, then the wheel and hub need to be balanced before fitting back onto the machine
it is best if you have a separate hub for each wheel.
31st Dec 2018, 07:07 AM #4Golden Member
- Jun 2004
- Kyabram. Vic
- 632
Agree with China. The small inner nut could well be a right hand thread as the hub has a keyway. The larger outer nut will most likely be a left hand thread so that it will not come undone during use. Rotation of the wheel will most likely be clockwise when looking at the outside face.
Ken
31st Dec 2018, 09:56 AM #5Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
It looks like the Macson I have here.
The large nut is RH thread, the small one LH thread.
There's a double ended tool for loosening the nuts, could be standard part.
The taper is quite steep, could be self-releasing not needing a puller.
I haven't had this thing running yet.
IMG_20181231_092933.jpgIMG_20181231_092926.jpgIMG_20181231_093139.jpgIMG_20181231_093200.jpg
31st Dec 2018, 11:08 AM #6Golden Member
- Jul 2011
- 837
Nadroj
Any chance of some dimension on that special tool?
I ran mine for a short while yesterday. The slideways need pulling apart for a good clean at minimum. There is some wear in the pinion shaft bearings that means there is a notchiness in the rack and pinion action. Have you removed the table from yours? How is it done?
Eric
31st Dec 2018, 11:10 AM #7Golden Member
- Jul 2011
- 837
31st Dec 2018, 11:24 AM #8Mechanical Butcher
- Oct 2004
- 1,898
31st Dec 2018, 12:57 PM #9China
- Dec 2005
- South Australia
- 1,658
William Sopko would very likely have the hubs ready made
1st Jan 2019, 07:09 PM #10Senior Member
- Dec 2009
- 327
'Waratah' spring hammer by Hands & Scott c.1911- 20, 'Duffy, Todd & Williams' spring hammer c.1920, Premo lathe- 1953, Premo filing machine.
1st Jan 2019, 07:43 PM #11Philomath in training
That's why we have machine tools...
//metalworkforums.com/f65/t1210...92#post1839492
1st Jan 2019, 11:06 PM #12Golden Member
- Jul 2011
- 837
Before I get to that I need to make some gadget to get the thing apart so I can measure it. But before that I have another project to finish. So don't be holding your breath. However I am betting by the time you factor in only having one hub the machine should be nearly free.
1st Jan 2019, 11:09 PM #13Golden Member
- Jul 2011
- 837
1st Jan 2019, 11:40 PM #14Most Valued Member
You'd better hurry up and get your Lathe working, so that you can make some too
By Alf Scotting in forum METALWORK GENERALReplies: 19Last Post: 7th Mar 2018, 11:14 AM -
Macson 2 as surface grinder
By StrayAlien in forum METALWORK GENERALReplies: 8Last Post: 18th Sep 2016, 09:41 PM -
By Petip in forum METALWORK GENERALReplies: 13Last Post: 26th Oct 2015, 08:02 AM -
DONE: Macson Surface Grinder
By GZBMW in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 18th May 2013, 11:14 PM -
SOUTH AUST Macson Surface grinder
By Kon R in forum METALWORK - Machinery, Equipment, MARKETReplies: 9Last Post: 22nd Oct 2012, 11:54 PM
