Results 1 to 3 of 3
Thread: Pullmax knowledge required
26th Dec 2018, 07:53 PM #1Senior Member
- Mar 2011
- Taree NSW
- 119
I have recently acquired a Pullmax without looking into its capability - it is set up for shearing and nibbling but it seems to me that with the appropriate tooling it could be made to planish and form radii which is what I originally thought I would be able to use it for
does any one have any ideas on this or do you also think it is possible?
regards to all and Merry Christmas for 2018
Alf
30th Dec 2018, 04:29 PM #2Most Valued Member
- Sep 2010
- Lebrina
- 1,916
That is very possible and there is a very large range of tooling possibilities out there. When attending TAFE, I took a bit of an interest in the one they had there and discovered tooling for forming radii, flanges, louvres, shearing, beading and just about any other process you could want. One of the teachers had on display on the wall behind his desk, a perfect replica of a bra with every piece made from sheet metal using the pullmax.
30th Dec 2018, 04:47 PM #3Most Valued Member
- Sep 2010
- Lebrina
- 1,916
Check these links for some inspiration.
https://www.pinterest.com.au/joemcgl...oling/?lp=true
https://www.trick-tools.com/tools/Pullmax-Dies
At the prices listed, I'd be making my own for sure!
Dismantling a Pullmax machine
By Alf Scotting in forum METALWORK GENERALReplies: 12Last Post: 26th Dec 2018, 08:10 PM -
In need of electronics/circuit board knowledge
By brendanh in forum METALWORK GENERALReplies: 30Last Post: 24th Jun 2015, 08:27 PM -
Turner 310x1000 knowledge
By Woolant in forum METALWORK GENERALReplies: 10Last Post: 12th Jul 2009, 11:38 PM -
Welding knowledge from Miller
By Buncha in forum WELDINGReplies: 3Last Post: 28th Mar 2008, 08:35 PM
