Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 84
  1. #31
    Jun 2010
    Canberra
    1,322
    i have since watched videos on youtube and when the guys reach the start of the job they turn off the machine than disingauge the feed than turn the.lathe back on and continue
    In my case, I'm looking to keep the thread cutter lined up with the threads I've already cut by leaving the feed engaged all the time - at the end of a pass, I stop the machine, withdraw the tool and then run the lathe backwards to feed the tool back to the start, then feed in deeper and take another pass. It works well provided you can stop the lathe quickly at the end of the pass.
    For this kind of thread cutting, the variable speed comes in handy, as I can temporarily speed up the machine while running backwards, making it quicker to reset for the next pass.
  2. #32
    Jan 2016
    Wodonga Vic
    38
    633
    I've tried using 150W light globes as resistors, it sure does stop the motor but there's a great BANG and flash of light from the globes and the motor moans and groans under the uneven forces generate during the stop. Can't imagine it's any good for the motor.
    The CNC lathe I use at TAFE has a hot plate element mounted at the back of it, is that for the braking?
  3. #33
    7,189
    Quote Originally Posted by NedsHead View Post
    Probably!
  4. #34
    jatt's Avatar
    jatt is offline Always within 10 paces from nearest stubby holder
    Bendigo
    51
    760
    After hearing (and seeing for myself) buying additional toolholders that aren't purchased with the QCTP [despite identical part no.s] -- may not fit. So good to see yours actually fitted on.
    Local joint up my way has a couple (one of which I scored to try at home) he ordered for a cust. You guessed it, so far out wont fit. Was hoping it would just need a skim on the flats. No such luck, dist between both sides of dovetail too small to fit tool post.
    DRO --yeah lots of bells and whistles, don't see myself even learning half of what it can do anytime soon.
    Like that toolholder mounted mill slide. Cant say I have seen one of those.
    Frisky wife, happy life. ​Then I woke up. Oh well it was fun while it lasted.
    From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
  5. #35
    6,477
    Hi Rusty Arc,
    The danger of running into the shoulder or even worse the chuck, is one reason I try and cut threads away from the chuck towards the tailstock running the lathe in reverse. I'm soon about to cut a left hand thread
  6. #36
    Aug 2009
    Sydney, NSW, Australia
    1,844
    That is a sensible practice Baron makes sense
  7. #37
    Jun 2010
    Canberra
    1,322
    Quote Originally Posted by jatt View Post
    Kind of, as mentioned, it's a looser fit, meaning I have to make sure to crank down on the top lever extra hard to make sure it's solid.
    That was a particularly sketchy setup - I just managed to clamp the edge of the vice in a spare toolholder, and was able to clamp the work at the right height for a single pass through the 3/8" endmill. That said, it all felt surprisingly solid.
  8. #38
    Jun 2010
    Canberra
    1,322
    That makes a lot of sense. Must try and remember that for next time...
  9. #39
    Jun 2010
    Canberra
    1,322
    Had a chance to remove the back plate and look at the variable speed drive that's in there. It's a Shinlin SS2 1.5kW vector drive with a 100R 600W braking resistor.
    Closer inspection shows that I was wrong about the closed loop operation - the RPM display on the lathe (and its sensor) is completely independent of the drive.
    I shot a video of the lathe stopping and went and counted frames - at 500 RPM it took 0.43 seconds to stop. At 1,000 RPM it took 0.9s.
    Having found the manual online, I tried changing the odd setting, but got an error message each time - there doesn't seem to be a password set, so not sure what's stopping it.
  10. #40
    7,189
    Quote Originally Posted by RustyArc View Post
    Assuming uniform deceleration, that's 7.5 completer revs at 1000 rpm and about half that at 500 rpm
    PLUS
    Reaction time, for a pedal while standing, unless you are prewarned something might happen, is around 0.5s (and this will be at full at full RPM) so you are looking at ~16 revs at 1000 and half that at 500 rpm.
    I doubt you will get that much better with a mechanical foot brake.
  11. #41
    Aug 2019
    Wellington
    11
    Very pleased to find this thread. Im looking at the 336D and contrasting it to to the 346V. Given the extra time with the new lathe how have you found it? Is the electronic brake delivering? From the discussions it should be stopping on a dime at threading speeds? How are you finding the accuracy on turning? How parallel is it turning over ~200mm? How is the torque? Are you able to manage ~2-3mm depth of cuts okay across a range of speeds? ie not torque issues with the VFD control?
    Appreciate any info, views, learning on this machine.
    J.
  12. #42
    Jun 2007
    Victoria, Australia
    114
    Does the lathe have a saddle lock?
  13. #43
    Jun 2010
    Canberra
    1,322
    Quote Originally Posted by jamesw View Post
    Really happy with it, but am still learning a lot. I am disappointed with the VFD brake - you can't really use it to stop the machine quickly enough if you're threading up to a shoulder, so I've now taken to threading in reverse (away from the chuck) with the cutting tool upside down on the other side of the work. I am confident I could stop the machine considerably faster with a mechanical brake.
    That said, for routine use, the quick stop that you always get with the electric brake is nice, rather than waiting for the machine to coast to a stop.
    I've done a few tests for taper where I adjusted the tailstock offset slightly, but apart from that, the machine seems to be very accurate. It's me that needs to learn/practise a lot more to get adept at turning to a diameter.
    I haven't really pushed it on DOC - with no experience on other lathes, I don't really have a yardstick for sensing how the machine is coping. With time I'll push it harder and probably start to find its limits.
    Very happy with the flexibility of the VFD, the DRO is great, and if they had included the mechanical brake with the VFD brake it would have been ideal.
  14. #44
    Jun 2010
    Canberra
    1,322
    Quote Originally Posted by topari View Post
    Yes, but it's just a cap head screw, not a lever, so I leave an allen key in it. Works fine.
  15. #45
    Aug 2019
    Wellington
    11
    Thanks for the response. Hope you don't mind if I ask some more questions and perhaps through some ideas about.
    Interested to understand this threading/braking side of things some more.
    Heres what I have found: I currently have an AL320G which is also metric leadscrew and has a chasing dial. When I am threading to a shoulder for metric threads and I can't (for whatever reason) use the safer running in reverse method I disengage the half nut. Wind the saddle back, wait for the correct chasing dial mark to line, re-engage the the half-nut to start the next pass. Obviously when doing imperial threads on a metric leadscrew lathe its a different story. However I would encourage you to look at Tom Liptons video on this. https://youtu.be/HXt4TWa382Q Even though he is using imperial leadscrew to cut metric the principle is the same You could use when dealing with Imperial would be exactly the same approach and allow you to use the half nut to actually stop saddle movement which is instant and the foot brake brings the spindle under rapid control. Another entertaining youtube is This Old Tony. He also has some threading video(s) that might be worth a watch. Remember what they do with Imperial and chaser dials you can do with metric and your chaser.
    So thinking about things and the way the electronic brake would seem to be operating when you thread what RPM you running at? I'm conservative and still tend to use 80-100rpm. So with the constant deceleration of that VFD (which would seem to have been programmed to drop 1Hz every 0.036 secs, again assuming it us using 50Hz as its base not 60Hz) that should be about 0.36 secs. Pretty quick stop. About half a turn. If running at 100rpm in low gear that should be around 0.45secs which is around 0.75 of a turn. If the electronic brake is delivering that performance things should be good for imperial threading to a shoulder as well. Again assuming you are not able to do the much better system of the reverse threading trick ala Joe P.: https://youtu.be/Z-dqOi_z5bk
    As a suggestion get a bit of round stock, ideally 45-60mm range but anything that is solid enough to not sink with an overhand and get it in the 3-jaw sticking out 150 to 200mm. Make sure its good and solid in the chuck then take light cuts down the length until its concentric. Measure with a mic at the chuck and then at the end. If they are within 0.02mm you are in a good space. If over that then your machine needs some adjustment as its cutting a too much of a taper. Do a search for Rollies Dad's Method of lathe alignment without cutting. But nothing beats doing test cuts as a final way to dial stuff in.
    The 346V is a meaty machine and with 2hp should be able to handle 2mm DoC easy. Probably more on bigger stock in low range. Of course you need the right sized cutting tool to do that. For example CCMT06 inserts are very happy at 1mm. Go beyond that and they don't like it. You need to move up to an 09 size for the 1.5 to 2mm area. If using HSS then its just a case of grind the correct tool shape for roughing cuts.
    I had a good look at at 346V at Machinery House today. Really pocked all over it and compare it to the 336D. Really hard to choose between them.
    J.
  1. Replies: 2
    Last Post: 15th Jul 2013, 01:24 AM
  2. Any Atlas Lathe and Drummond Lathe Owners out there?
    By j.ashburn in forum METALWORK GENERAL
    Last Post: 8th Apr 2013, 06:22 PM
  3. SOLD: Lathe for Lathe Drill Mill (Near Liverpool NSW)
    By Auskart in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 29th Jun 2010, 07:02 PM
  4. Buying a lathe (Old massive Lathe, or New small C6 Lathe)
    By Ch4iS in forum METALWORK GENERAL
    Last Post: 25th Mar 2009, 12:19 PM
