Results 1 to 13 of 13
Thread: face mill cutters
2nd Dec 2018, 04:48 PM #1Senior Member
- Mar 2011
- Taree NSW
- 119
face mill cutters
Have 2 face mills both requiring new cutters - the R8 arbor one has tools 1/2" sq. x 38 lg.- the morse taper one has tools 10 mm.sq. x 38 lg. - have looked on ebay and Hare & Forbes to no avail - perhaps you can help - having trouble loading photo
2nd Dec 2018, 05:17 PM #2Gear expert in training
- 34
- 1,079
Can't the inserts be sharpened? Look like there's a lot of carbide left there
EDIT: On second thoughts, given that you can buy a shell mill and 10 inserts for $50, is it worth trying to find the old style? https://www.banggood.com/Wholesale-M...ol-c-6528.html
2nd Dec 2018, 11:10 PM #3
Hi Alf,
Now having seen the pictures, I would suggest the same as I did in my other post !
A new insert shell mill and arbour is not expensive at all ! Those things in your picture should be re-purposed, though I do have a couple of similar inserts that I've been considering trying as lathe tools.Best Regards:
3rd Dec 2018, 07:30 AM #4Philomath in training
Could you buy a 1/2" lathe tool and put that in there? (use it as a fly cutter with a single tool).
A diamond wheel will sharpen those but I always wonder how to line them up later so they are all spot on. Without that, the roughing really is...
3rd Dec 2018, 08:02 AM #5Most Valued Member
- Australia east coast
- 2,713
My suggestion - drop them in the bin if you can't salvage the arbors and buy something like this instead.
https://www.ebay.com.au/itm/NEW-R8-F...item3d763f0dcd
PDW
11th Dec 2021, 08:25 AM #6New Member
- Jun 2021
- Victoria
- 9
With these face cutters are they generally specific arbors or can you attach the actual face cutter to a different arbor?
Just to clarify, I’ve bought a mill, not picked up yet but need tooling. I’m entirely new to mills.
11th Dec 2021, 09:43 AM #7Philomath in training
Usually there is a screw or bolt up the middle so the cutter can come off the arbor. The arbors where they bolt onto the cutter are not standard though, so measure what you have have so you can buy a cutter and/or arbor to suit.
11th Dec 2021, 10:05 AM #8New Member
- Jun 2021
- Victoria
- 9
Thanks, Ill do that when I get it. I was confused because the cutter had R8 on it so I thought it meant for one arbor type. I’ve since worked out that on a Widax the R8 means the cutter number.
Im a bit confused by the arbor designation when I look around. Is Iso30, NT30 and BT30 all the same or are they all different.
The machine I bought is secondhand and it’s a bit of a drama to collect with Covid rules in that state. Need to do multiple tests etc. I’m trying to combine pickup with a visit to my mother who lives there.
11th Dec 2021, 10:42 AM #9Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
NT30 and BT30 are sort of the same but with different holding systems. Of the two NT30 is the usual arbor on a manual mill and is held in place with a (usually but not always) M12 draw bar.
11th Dec 2021, 02:27 PM #10Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
Iso 30, NT30 & BT30 all have the same taper, ISO and NT are mainly for manual machines, ISO has a metric drawbar thread and NT is imperial. BT30 has a thicker flange with a groove to engage with a toolchanger arm, and it doesnt have the parallel section at the small end of the taper, they can be used in a manual machine if you use a longer drawbar or make a adapter to screw in the end like this: https://www.machineryhouse.com.au/T144 This one is for BT40.
11th Dec 2021, 05:58 PM #11Most Valued Member
- 2,666
Just be aware that there are “NT” arbors available for sale that have metric threads for the drawbar.
I think that technically makes them NOT an NT type, but regardless - the important thing is don’t automatically assume that ISO is metric thread and NT is imperial. Always confirm.
11th Dec 2021, 09:37 PM #12Golden Member
- Oct 2001
- ACT
- 667
those face mills can do an ok job when not blunt.
easy enough job to sharpen with the right equipment...
14th Dec 2021, 11:57 AM #13Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,195
I agree with Elan and PDW. 'tis sometimes not worth persevering with strange old milling (or lathe parting) holders.
I found a Widax M680 239.69.046 (Ø80). Looking at the manufacturer, it takes six XPHT/XPNT 1604.
Not a common shape:
Left is the (worn) XP_T. Middle is an APGW15T320R, and right is an APMT160512PDER.
The AP__ series is easy to find and cheap, an 85° parallelogram.
The X series is supposedly "custom", but looks about 82° to me.
Face milling cutters
By Alf Scotting in forum METALWORK GENERALReplies: 2Last Post: 1st Dec 2018, 08:48 PM -
Face mills and Fly cutters
By simonl in forum METALWORK GENERALReplies: 10Last Post: 7th Jan 2012, 09:22 PM -
Face Mill Fly Cutter
By RayG in forum METALWORK GENERALReplies: 19Last Post: 26th Oct 2011, 09:42 PM -
Recommend a face mill please
By morrisman in forum METALWORK GENERALReplies: 6Last Post: 8th Sep 2011, 07:46 PM -
CTC Face Mill - Any Users?
By Anorak Bob in forum METALWORK GENERALReplies: 61Last Post: 6th Jan 2011, 01:41 PM
