Results 106 to 120 of 174
Thread: Horizontal Bandsaws
25th Jan 2019, 11:11 AM #106Most Valued Member
Bob,
I assume that mod seriously reduces the torque though. How does it go on tougher materials? Does the motor get hot?Chris
25th Jan 2019, 01:25 PM #107Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
Hi jack,
I have only done a couple cuts of some 25mm diameter pieces of steel bar, it did not have any trouble cutting this.The cutting time was considerably faster. Before this modification the motor would be quite warm almost too warm to put your hand on when cutting larger diameter sections or doing multiple cuts over a short time period . I have been told that this is a normal temperature for this style of motor. In its standard form these saws in my opinion place far too much load on the blade and the motor, this is part of the reason that it is hard too keep them cutting straight. This is why I have added the hydraulic down feed control and the spring buttons and always use cutting oil. With the now 50% increase in surface feet speed I would expect the chip load per tooth to be reduced and therefore the motor load should be lower. I will keep an eye on it when I cut a heavier section.
Bob
11th May 2019, 03:00 PM #108Most Valued Member
Precision Horizontal Bandsaw Alignment
Found this in an email that was sent to me. Utilising a 1 2 3 Precision Block.
Thought it was a unique way of setting up the fixed jjaw square to the blade.
https://rick.sparber.org/PrecisionHo...wAlignment.pdf
A bit further down the email was this handy idea, for holding odd shaped bits, but requires drilling and tapping the bed of the saw.
Holding Odd Pieces In 4x6 Metal Bandsaw - HomemadeTools.net
Aslo one for the theorists out there, on slack blades
https://rick.sparber.org/SlackBlade.pdf
Hope this helps someone.
11th May 2019, 06:50 PM #109Banned
- Jan 2019
- 78
I've had my BS-5S for around three years, in that time I have never changed speeds. After destroying one bimetal I went to carbon and blades last quite a while if under coolant. Bimetals may be good for solids but for thin walled tube they are hopeless.
11th May 2019, 07:05 PM #110Most Valued Member
Bimetal is all I've ever used, 24tpi cutting thin tube, pipe, solid bar, sheet, angle, cast and just about anything else, it's been cut in my saw, and not with coolant either.
11th May 2019, 07:46 PM #111
Totally agree, I've bought 2 bimetal one's 15/20 years ago and ripped teeth off and 18tpi was the finest the saw blade place carried, the 24tpi mentioned might have been better.
Went back to the carbon and then went coolant a few years latter and never looked back.
I've been using the 6x4 saw in this place for 12 months with out running coolant, just haven't bothered mixing it and jobs needed doing.
After just 6 months on a new blade it broke a few days ago, so back to coolant.
It could have just been the blade, but I'll blame running dry lol, I get way more life out of them than that and use it alot expecally on thin RHS.Using Tapatalk
11th May 2019, 08:46 PM #112Member: Blue and white apron brigade
I've gone the other way - used to use only carbon bands, but now I only use bimetal once I found out the down force has to be backed off a bit for tubing compared to solids. This is MUCH easier to do with a hydraulic damper than the usual spring arrangement. I use 10-14 for everything and haven broke any teeth in at least two years.
11th May 2019, 09:44 PM #113
12th May 2019, 12:50 PM #114Diamond Member
- Aug 2006
- 1,106
Dave J: Could you post up the link for that valve?
12th May 2019, 01:04 PM #115
12th May 2019, 01:07 PM #116Diamond Member
- Aug 2006
- 1,106
Do those have the one way check valve in them though?
12th May 2019, 01:56 PM #117
I just had another look and now I'm not sure they do, I know these do
Using Tapatalk
12th May 2019, 06:19 PM #118
Ditto with my BS4.
I used 10/14 pitch on the stiddy cut from the cane tram line and used a can wd-40 -with a straw attached- to periodically wash away the chips.
The blade is due for change now as its done over 200 cuts and cutting ok but out of square.
Once that happens there is no adjusting it back as there in uneven wear on one side of the blade.
The real trick is to have all adustments dead nuts square and follow a run in procedure.
12th May 2019, 08:09 PM #119Most Valued Member
Grahame, is your blade slightly curved across the face from teeth to the back?
If so, you have too much pressure on the rolller, causing the blade to dish. There needs to be just enough pressure that the blade can be slid out with just a touch of drag, when its not on the wheels.
29th May 2019, 12:55 PM #120
great thread, I've enjoyed reading the comments and great ideas on modding these small saws. Today I finally purchased a Saber 115mm Bandsaw and will be implementing many of these ideas, the first of which will be to replace the spring down feed adjuster with a hydraulic equivalent. Ive seen a few videos on YouTube and so have a rough idea what needs to be done. Wonder what others have use for the hydraulic cylinder , also if anyone has a link etc to what other build etc.
TIAHafco AL320G Lathe
Toolex RF31 Mill/Drill
Saber Bandsaw
Power Hacksaws V's Bandsaws
By simonl in forum METALWORK GENERALReplies: 342Last Post: 9th Jun 2019, 09:18 PM -
Metal Bandsaws.
By wm460 in forum METALWORK GENERALReplies: 28Last Post: 8th Jul 2015, 10:23 PM -
thoughts on bandsaws
By texx in forum METALWORK GENERALReplies: 13Last Post: 5th May 2015, 02:33 PM -
Something to check for on small bandsaws
By Michael G in forum METALWORK GENERALReplies: 16Last Post: 25th Dec 2013, 06:06 PM -
Metal Cutting Bandsaws
By silash77 in forum METALWORK GENERALReplies: 15Last Post: 7th Jun 2009, 02:55 PM
