Results 1 to 11 of 11
Thread: Segmented belts
14th Nov 2018, 03:52 PM #1
Segmented belts
I’ve just finished getting the little mill running and I have fitted a red segmented belt. It is producing some vibration and I’m wondering if it will bed in and stretch and when that happens it will smooth out?
If so does it take long? I have taken the tension off the belt maybe I should leave it on for a while to speed up the process?…..Live a Quiet Life & Work with your Hands
14th Nov 2018, 07:35 PM #2Most Valued Member
- 4,890
What type of vibration if any were you getting with a standard Vee belt.
14th Nov 2018, 07:46 PM #3Most Valued Member
- Jul 2016
- 35
- 1,522
I highly suggest the leather segmented belts. Red power twist is horrible stuff, the corners of each piece are too sharp and tough. G and R industrial in Fitzroy stock made in Australia leather belting. I just bought 7 meters of C section for my DSG and it's very quiet.
No affiliation just happy customer.
14th Nov 2018, 07:56 PM #4
14th Nov 2018, 07:59 PM #5Most Valued Member
- 4,890
Any thought that the vibration is from somewhere else.
14th Nov 2018, 09:26 PM #6
Hi Dean,
Is it running in the right direction ?
Some of these link belts are intended to run only one way.Best Regards:
14th Nov 2018, 09:34 PM #7
Didn’t know they ran one way or which way this one should. I know it’s the right side up.
15th Nov 2018, 11:22 AM #8Golden Member
- Dec 2007
- 574
I fitted a B section power twist (green links) to my lathe and found that there was less vibration than with the original standard belt, it looks in the photo that you have a tension device fitted down near the pivot point of the arm that the motor is mounted on, that arm is quite long and will have a certain amount of flex, having the motor mounted up high on the arm would not help - if it were me I would fit a steady from the top of the arm and back to the top of the mill, it wouldn't take much effort with some G clamps and a length of steel tube to rig a temporary steady and see if that has any affect on the vibration.
15th Nov 2018, 11:54 AM #9
Dale, you haven't fitted the latching belt tensioner yet (that would act as a clutch as well).
Like familyguy, I suspect that would fix or reduce you vibrations enormously.Cheers, Joe
15th Nov 2018, 11:58 AM #10
Joe, it doesn’t fit. I’ll have to work out some sort of modification and try to make it work.
15th Nov 2018, 03:06 PM #11Senior Member
- Jun 2013
- Tasmania
- 257
Hmm, I was wondering about this very thing. I bought a link belt last week and its a very stiff plastic kind of one and I wondered how it will go. I was expecting to get a leather type one, I'm a bit concerned as I don't think this plastic one will ever soften up and probably isn't even designed for smaller pulleys (say 2"+). It was pretty pricey too at about $50p/m, I needed to buy 2m . Then it turns out I didn't actually need it as I changed the motor arrangement on the band saw and it then allowed fitment of a standard V belt I had on-hand.
Given I've got it I might install in anyway and just see how it goes. I've been trying to isolate a vibration in the bandsaw (I was ruling out a set in the V belt) but I think I tracked it down to the bigger pulley on the lower wheel being ever so slightly out of true. I also thought I could put the belt on the Hercus. Anyway, will be interesting to see if I get any fine vibrations from the belt.
Linked V belts
By Swarfmaker1 in forum THE HERCUS AREAReplies: 11Last Post: 22nd Jan 2016, 06:59 PM -
Cogged belts - again
By eskimo in forum METALWORK GENERALReplies: 3Last Post: 27th Aug 2014, 11:09 AM -
Twist lock segmented v belt
By TomW in forum METALWORK GENERALReplies: 31Last Post: 8th Jan 2014, 10:34 AM -
Flat Belts
By Fossil in forum METALWORK GENERALReplies: 11Last Post: 8th Jun 2008, 10:08 PM -
Link belts
By warren in forum METALWORK GENERALReplies: 13Last Post: 23rd Mar 2007, 10:09 PM
