Results 16 to 21 of 21
Thread: My consolidated workshop thread.
18th Nov 2018, 08:26 PM #16Philomath in training
- 6,540
In theory you could plunge hob, but the cutter would be quite complex to get the right shape. On the hob that I made, self feeding was easy - the cutter was just a worm with a slightly larger diameter, flutes were on the mill and relieving was done with an angle grinder.
18th Nov 2018, 08:59 PM #17Most Valued Member
- Jul 2016
- 35
- 1,522
Okay, The DSG has metric changegears so ill start by making a hob, I guess i can just pre gash the teeth with a slitting saw or gear cutter. How deep did you make your gashes before starting the hobbing?
18th Nov 2018, 09:13 PM #18Philomath in training
- 6,540
Metric change gears are not going to work. A worm & wormgear set is done on circular pitch - that is, the PCD of the gear x Pi/n. The number is usually not a nice round one, hence the gears. To cut a double start M2 worm (or cutter) on my lathe I would need to dial up 3tpi and then run it through a 33/49 gear pair to get the right pitch.
18th Nov 2018, 09:24 PM #19Golden Member
- Jul 2011
- 837
There was an article about relieving hobs on the lathe with a tool on a sliding mechanism driven by a cam in Model Engineer's Workshop about the same time as they serialised a version of the Jacobs hobbing machine.
28th Dec 2018, 11:45 AM #20Most Valued Member
- Jul 2016
- 35
- 1,522
Okay so a bit of progress has been made, Im hoping to have it running next week. I have the new worm in the feed gearbox and the feed gearbox back in the base of the machine. I really regret cutting the wiring to the two speed feed motor as beeping it all out and labelling it took a bunch of time but thems the brakes. I wanted to use some quick disconnect MIL style plugs to rejoin it, and i bought one at significant expense from RS but the contacts were very small and i just couldnt get seven strands of 16g wire packed in there.
IMG_20181219_124538.jpgIMG_20181219_152335.jpgIMG_20181227_160931.jpgIMG_20181227_183439.jpg
I also made a sleeve to repair my other butchery cutting the y axis driveshaft and have replaced every bearing i could get to. There were just chips everywhere, even packed under the bottom of the knee somehow.
Right when i was filling the gearbox I found why there was absolutely no oil in there when i pulled it out. The filler neck that pokes out the front has a drain and a fill plug, the fill plug it vented with a hole in the middle and they were swapped! I have no idea how it wasn't seen as the oil puddle would have been massive. (6 litres in this box and 26 in the main gearbox)
14th Aug 2019, 11:23 PM #21Most Valued Member
- Jul 2016
- 35
- 1,522
A couple of weeks ago with the help of another forum member I dismantled the apron of the DSG and found why the half nuts wouldn't engage. The handle just would not budge.
The two halves of the half nuts are die cast in some kind of aluminium alloy, thankfully stronger than Zamak but still not a great choice.
Someone had just busted the bottom of one of the cam tracks straight off.
I don't have a good before picture but in one where I'm milling it off you can see the big chunk broken off.
I used a piece of cast iron, thanks again Kryn!
It's held on by SHCS and some 3mm dowel pins. Hopefully it holds up. I plunged the boring head down multiple times to rough it it and then finished blending it with a file.
If anyone gets this model of DSG I would reccomend inspecting these as the alloy had swollen and jammed in its ways, causing someone to bust it trying to engage them.
Thread for Workshop Jacks
By electrosteam in forum METALWORK GENERALReplies: 13Last Post: 3rd Jan 2014, 08:44 PM -
My workshop
By Jan Nieuwenhuis in forum METALWORK GENERALReplies: 32Last Post: 16th Jun 2013, 08:01 AM -
Possible new workshop
By Sterob in forum METALWORK GENERALReplies: 12Last Post: 8th Jun 2008, 12:33 PM -
New Workshop
By Paulxsteel in forum METALWORK GENERALReplies: 7Last Post: 25th Feb 2008, 11:09 AM
